prelude to civic engine swap??
Old 08-01-2006, 01:07 AM   #1
Rep Power: 0 keith_j1 is on a distinguished road
Default prelude to civic engine swap??
i want to know what year civic hatch i can drop the 97-01 H22 motor into?? and does it bolt to the civic Manual transmission??
keith_j1 is offline   Reply With Quote
Old 08-01-2006, 02:09 AM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Rep Power: 288 Calesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud of
88-00
No it won't bolt to a Civic transmission... at least not without an adapter plate.
Old 08-08-2006, 01:49 PM   #3
Rep Power: 0 ispool2 is on a distinguished road
This swap is hard to do as well as expensive! Awsome power, but front heavy. If you plane on going around corners fast. Forget this swap! Good luck!
ispool2 is offline   Reply With Quote
Old 08-08-2006, 03:02 PM   #4
Rep Power: 7 eludethis is on a distinguished road
most civics with H22 i see are set-up for drag only. converting the rod shifter to cable shifter is not that hard. unless you want to use a B series tranny then you can use the H2B plate. that way you can use the rod shifters. either way it will cost $$$. Hasport makes mount kits for H22 swaps into civics. keep in mind that you will need wire harnesses if you plan on using that motor in older civics (obd1).
you should be posting this in the civic forum, not the prelude forum.
If you'd rather hear it from someone with a little authority, I have just as little as anyone else.
eludethis is offline   Reply With Quote
Old 08-08-2006, 03:07 PM   #5
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
Rep Power: 177 reikoshea has a reputation beyond repute
reikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond reputereikoshea has a reputation beyond repute
myspace
this is in the wrong forum, moved.
Anime Informant
reikoshea is offline   Reply With Quote
88+ ECU Error Codes pissedoffsol Reference Materials 1 05-19-2005 01:03 PM
97 Civic HX- Swap the engine? Phade HYBRID -> EG-EK / DC 8 09-23-2004 12:35 AM
Need some help with Trim Names YangpaNemsay General Tech and Maintenance 7 08-31-2003 04:43 PM
81 Civic Engine Swap Help fjcisco13 HYBRID -> EG-EK / DC 3 04-23-2003 06:16 PM
Chassis Code VSMB16A2 General Tech and Maintenance 10 01-22-2003 05:32 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
