PROBLEMS need addressed now that I have some TIME to deal with them
Old 03-01-2008, 05:09 PM   #1
Lick my nuts.
93civicracer's Avatar
Ride:  '90 Accord DX, '93 Civic JDM D15B
Rep Power: 32 93civicracer is a jewel in the rough93civicracer is a jewel in the rough93civicracer is a jewel in the rough93civicracer is a jewel in the rough
Send a message via MSN to 93civicracer
Default PROBLEMS need addressed now that I have some TIME to deal with them
Alright here's the problems and other weird things I need to check out:
1. Still bogging at 1400-1500 rpms sounds like rev limiter, ignition timing is now dead-on. Cam timing? Quickest and easiest way to check cam timing? Could this even be the cause?
2. When I do redline pulls it seems like FIRST gear is hitting rev limiter at 6600 rpm, while the rest make it past 7200 rpm. What is this?
3. When I'm slowing down, there's a knocking sound coming from the front-right. Axel problem? Why is it doing this? Sounds exactly like a bad tie-rod but my car doesn't have tie rods.
4. The valve cover sometimes feels hot, and sometimes it doesn't. Overheating? I went to Autozone and I have a new fan switch gonna install it later.
ANY INPUT is very much appreciated I finally have time today and part of tomorrow to do something about these.
I'm saving up to replace the whole cooling system, new aluminum radiator dual-core, new fan and motor, waterpump, thermostat, all new hoses and clamps, timing belt, oil pump, fuel filter, battery and alternator, basic tune-up. Gonna start using Castrol Syntec oil also, 5w-30.
Originally Posted by dacheat View Post
eh, i'm a fan of the dick beatdown.
93civicracer is offline   Reply With Quote
Old 03-01-2008, 06:55 PM   #2
Lick my nuts.
bump
Old 03-01-2008, 09:37 PM   #3
Lick my nuts.
bump, need help
and if I were to adjust timing (it seems to only be a little off IF that's what's causing the engine to bog at 1500) then couldn't I just slide the belt off the cam pulley, rotate the came pulley by a tooth, and keep going til it's running right?
Old 03-02-2008, 01:10 AM   #4
99sidude's Avatar
Ride:  gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
Rep Power: 50 99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of
Send a message via AIM to 99sidude
The valve cover IS going to get hot. No question about that its normal. What ecu are you running?
Originally Posted by Celerity View Post
The worst thing that car ever had installed was your lying two-bit fat ass in the left seat.
My Build: http://hondaswap.com/auto-multi-medi...sc-buld-94841/
93' dx hatch
jdm b18c - jrsc 8psi
s300 440cc RC's
99sidude is online now   Reply With Quote
Old 03-02-2008, 01:16 AM   #5
99sidude's Avatar
Originally Posted by 93civicracer View Post
bump, need help
Ok, rotate the crank pulley until the tdc mark is alligned. If the tdc mark on the cam gear is also alligned, then you're fine. If not, take the belt off and put it back on so they are.
93' dx hatch
s300 440cc RC's
Old 03-02-2008, 01:30 AM   #6
Lick my nuts.
I'm running the jdm p08 meant for the d15b vtec. Thanks for clearing up the hot valve cover deal it's just that it's sometimes hot, sometimes not.
And about the timing, can I do that without having to take off the lower cover and all that other shit like the p/s and alternator?
Old 03-02-2008, 01:40 AM   #7
99sidude's Avatar
to adjust it you're gonna have to pull all that shit off. To check it you dont. Just pull the upper cover to see the cam gear.
93' dx hatch
s300 440cc RC's
Old 03-02-2008, 01:57 AM   #8
Lick my nuts.
I thought you could just like slide the belt off from the cam gear and rotate the cam gear over a tooth or so then just keep doing that til it's running right. Thanks for the advice tho, any advice on the other problems?
Old 03-02-2008, 02:04 AM   #9
99sidude's Avatar
You may be able to do that. On my engine I have to pull the belt off of the tensioner to adjust the cam timing. Don't just adjust it till it runs right. Set it so the TDC marks on both pullies are alligned. Honda did that to make it easy for you so you dont have to do it trial and error.
93' dx hatch
s300 440cc RC's
Old 03-02-2008, 02:09 AM   #10
99sidude's Avatar
Describe the bogging in more detail. It it always bogging at 1400 rpm's? Does it do it all full throttle? How does the car behave at part throttle (i.e. cruising at constant speed)?
93' dx hatch
s300 440cc RC's
Old 03-02-2008, 02:14 AM   #11
Lick my nuts.
See it's like this. When you try to hold the throttle at 1400 rpms or slowly (really slowly) raise it, it sounds just like rev limiter but a little slower. And the more gas you give it (slowly while around 1400 rpms is where it starts) the more gas, the slower it hits and the harder and louder it sounds. When you full throttle that shit it just passes the 1400 area normally, and if you do it slow, it bogs at 1400 until you give it enough gas then it starts acting normal at like 3500-4000 rpms. Also it JUST started doing this only every now n then, but when you try to hold speed sometimes, it sounds real nasty and vibrates like hell and slows down, then I floor it to get back up to speed then I can hold it just fine. I'm guessing THAT's the TP sensor (which isn't throwing a CEL) but not sure about the bogging.
Old 03-02-2008, 02:23 AM   #12
99sidude's Avatar
See it's like this. When you try to hold the throttle at 1400 rpms or slowly (really slowly) raise it, it sounds just like rev limiter but a little slower. And the more gas you give it (slowly while around 1400 rpms is where it starts) the more gas, the slower it hits and the harder and louder it sounds. When you full throttle that shit it just passes the 1400 area normally, and if you do it slow, it bogs at 1400 until you give it enough gas then it starts acting normal at like 3500-4000 rpms. Also it JUST started doing this only every now n then, but when you try to hold speed sometimes, it sounds real nasty and vibrates like hell and slows down, then I floor it to get back up to speed then I can hold it just fine. I'm guessing THAT's the TP sensor but not sure about the bogging.
LOL this sounds like exactly what my car has been doing for awhile. It still isn't fixed so you can take my advice with a grain of salt.... I initially thought it was the tps. I repaced that, nothing. I then checked fuel pressure. It was way too high. I bought a FPR to turn it down, and while I was able to reduce it, it still it too high. That didn't fix anything. Keep in mind I have a Walbro pump pushing alot more volume of fuel.
I had changed the plugs and wires, and that didn't do anything. My next step is the distributor. That is in shippment right now so i'll have to get back to you on how that goes. Ignition could be your problem. Think about it. Our motors are at least 13 years old. Thats a lot of time for rubber and plastic to get old and fail.
I have a wideband on my car and the car has always ran really rich at idle and part throttle. Infact it runs richer at idle than at full throttle. Fucked up I know.
First id check the cam timing. If thats not it look at the ignition.
93' dx hatch
s300 440cc RC's
Old 03-02-2008, 02:28 AM   #13
Lick my nuts.
Damn if I had a video camera I'd post a vid to let ya know what it's like. But yea my ignitions good timing is dead-on and I don't see why the ignition timing would do that.
Old 03-02-2008, 02:32 AM   #14
99sidude's Avatar
If something in the system that delivers the spark is bad, then having your ignition timing set right doesn't mean shit. If something is fowled up, then the system might not be delivering spark when it shoud, causing the bogging.
93' dx hatch
s300 440cc RC's
Old 03-02-2008, 04:36 AM   #15
Lick my nuts.
Could it be a battery cable going bad? Last I saw when I wired in my vtec my positive battery cable was pretty bad. Like most of the outer wiring is severed but the inner wiring is good, gonna replace that for sure.
The reason I saw it was because I was having so much trouble trying to get the vtec wires thru the firewall where the engine harness goes thru, you know thru that rubber cover? I couldn't get thru so I just routed it over the fuse box inside the fender thru the door and grounded it to one of the bolts on the inside of the door, looks kind of cheap you can see the vtec wires going under the carpet I tucked it in as best I could tho so it ain't too bad. LOL
Old 03-02-2008, 04:37 AM   #16
Lick my nuts.
Also if there was a problem with the spark then why the hell would it only do it at a certain area?? Wouldn't it affect it at all rpms?
Old 03-02-2008, 07:11 AM   #17
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
Rep Power: 122 92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
I stopped reading halfway down.
To adjust timing, mark your distributor (so you know where stock is) and just turn it to advance or retard timing.
DO NOT PM ME WITH TECH QUESTIONS!!!
Current Rides
1992 Chevy S-10 Ext. Cab
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned,
253whp
1994 Civic VX Hatch, 1992 b18a1 swap
1993 Civic CX Hatch, 2000 B18b1
92civicb18b1 is offline   Reply With Quote
Old 03-02-2008, 12:05 PM   #18
99sidude's Avatar
Get the cable fixed, and check the cam timing. Then go from there
93' dx hatch
s300 440cc RC's
H22A Automatic Swap Problems hahakenny HYBRID -> BA-BB /CA-CD 13 10-24-2007 02:16 AM
Time pressures... totalburnout Members' Lounge 16 04-18-2007 07:50 AM
d16y7 1/8mile time D15Z1 HYBRID -> EG-EK / DC 4 08-27-2003 02:04 PM
Axle Clicking Problems, For The 3rd Time.... sol2nr HYBRID -> EG-EK / DC 6 05-23-2003 12:38 PM
Code 45 Fuel Problems dokta-dee ECU's, Electronics, and Tuning 1 04-08-2003 10:36 PM
