putting a b16 into a 1996 honda civic ex
Old 03-01-2005, 04:59 PM   #1
Rep Power: 10 civic_driver_389 is off the scale
what is involved with putting a b16 motor into my 1996 honda civic ex? Do i need a motor mount kit? What else will I need?
civic_driver_389 is offline   Reply With Quote
Old 03-01-2005, 05:03 PM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
depends which b16 you get. theres at least 7 different versions.
if you get one from a usdm 99-00 civic si, its the least amount of work.
Old 03-01-2005, 05:50 PM   #3
Would I need anything else besides the motor, tranny, ecu, and wiring harness
Old 03-01-2005, 06:11 PM   #4
Eh6
Rep Power: 11 Eh6 is off the scale
You would have to redue the wiring because your car is obd2a and the 00 civic si b16 is obd2b, but you can just use your harness from your car, and since your car is already wired for vtec, then you its a matter of mixing and matching civic and integra mounts... do a search for some more info. later
Eh6 is offline   Reply With Quote
Old 03-02-2005, 07:55 PM   #5
Rep Power: 11 civic32958 is off the scale
b series motor mount kit
b series sfiftlinkage
00 si rear transmisson bracket
civic32958 is offline   Reply With Quote
Old 03-02-2005, 11:04 PM   #6
Ride:  RX5.7 Civic LS and Teg Ls
Rep Power: 25 civiclxb16 will become famous soon enough
Send a message via AIM to civiclxb16 Send a message via Yahoo to civiclxb16 myspace
becareful with the mounts because there is a difference with the integra and the 96-00 driver side mount
Check Out My Car Club
www.HighRevCustoms.com
and join the forums
this is what happens when you are bored out your mind!!:|
my current baby http://i114.photobucket.com/albums/n.../myspacefc.jpg
civiclxb16 is offline   Reply With Quote
Old 03-03-2005, 09:23 AM   #7
Originally posted by civiclxb16+Mar 2 2005, 11:04 PM--><div class='quotetop'>QUOTE(civiclxb16 @ Mar 2 2005, 11:04 PM)</div><div class='quotemain'><!--QuoteBegin-civic32958@Mar 2 2005, 07:55 PM
[/b][/quote]
Can I just get a motor mount kit and a shift linkage kit from hasport or something like that. I saw that they make a kit for putting a b series into my car, but it is pretty expensive. is there a cheaper way, or should I just go with that.
Old 03-03-2005, 01:58 PM   #8
Rep Power: 15 DelSlo is off the scale
research the ish.
and its cheaper to use the OEM mounts than the hasport kit.
93' Del Sol
2000 B16A2 swap.
garrett T3/T4 (.48/.60)
Weapons of choice.. Innovate LC1 and Crome Pro
Faze EL Engine management guages.
DelSlo is offline   Reply With Quote
Old 03-03-2005, 02:49 PM   #9
Rep Power: 20 smooth_criminal is off the scale
you don't need new mounts. Just brackets. you'll need a 99-00SI rear & Driver side brackets. Any any b series front tranny backets. USe your stock top trannny bracket you can leave all your stock mounts alone if they are in good shape.
You hate me because i'm different;
I hate you because your all the same!
G-Driver.
smooth_criminal is offline   Reply With Quote
Old 03-03-2005, 06:15 PM   #10
Where can I get the brackets? Do I also need shift linkages? if so which ones
