i recently did a swap (first time)...and was wondering if there is anything that is suppose to be done to the clutch system in order for it to work...i mean like linkage or cable....
i'm asking because when i started the car yesterday, it fired up but i can't shift into gear...and it seems like the clutch pedal is not even engaging so am i missing a line or something? car is a 93 hatch with a 94 b18b...thanks |
#2 | |
aww...sorry i'm a new in swaps....oh i think i know what you mean now...so after bleeding it is there any other lines that i should connect?
Now your transmission has a shift linkage and a support beam that cradles your shifter, both these must be connected, the linkage is held in by a little pin. You have these connected correct? And do you know how to bleed your clutch?
My Microvan Brakes For Bingo, Grocery Stores, And Soccer Practices. |
#5 |
yea i have those things hooked up already...as far as bleeding goes i think i do...i think i have to loosen the little valve looking thingy in front of the transmission and press on down the clutch pedals several times? is that correct?...thats just my guess from taking a glance at it when i was at home...
#6 | |
SOHC VTEC at its best
Ride: 95 Civic EX Coupe
95 Civic EX Coupe: GSR suspension rear LCAs & tie bar Turbonetics t3/t4B (ceramic ball bearing) Super V Trim, Stg 2 .48 A/R Xenocron basemap on P28 @ 9.5-10psi Greddy Type RS bov Tial 38mm WG GOAUTOWORKS cast mani, 3" DP, WG dump, oil lines, & Aluminum rad/fan combo. Spearco Intercooler 450cc DSM blue tops walbro 255 HG and ARP studs Competition Clutch Stg5 w/4puck disk BF Goodrich Drag Radials Soon to have: 15" Rota Slipstreams hondata 3bar map tune by Darren in Baton Rouge, LA on 12psi |
#7 |
Swapper for life!
Ride: 92 Civic lx w/ LS Swap
yes, hold down the clutch pedal while your buddy opens the line to bleed, and leave it down until it's closed again. then just keep repeating until a good steady squirt comes out...
......yeah, I know....... that's what she said __________________
"everything in a honda is glued together. You just hook up an engine lift and rip that fucker out" -klyph 92 Civic LX 4Dr -LS Swap -Fidanza lightweight flywheel -Exedy clutch -Ebay Ram air -Ebay Short shifter -APC racing seats |
| quick question...h22 swap.. | itz_j1n | HYBRID -> BA-BB /CA-CD | 18 | 12-17-2007 03:50 PM |
| Quick question.. | MSRJDub | HYBRID -> ED-EF / DA | 3 | 05-03-2007 05:35 PM |
| Quick question needs quick response. lol. | 5speed4life | HYBRID -> ED-EF / DA | 5 | 02-24-2006 03:22 PM |
| quick question on tranny swap | LOS222 | HYBRID -> BA-BB /CA-CD | 8 | 03-20-2005 03:24 PM |
| Quick Swap question | hondanewb | HYBRID -> EG-EK / DC | 3 | 08-18-2003 03:41 AM |
