Removing tranny from motor ?
Old 07-24-2006, 08:41 PM   #1
Rep Power: 8 forsakened is off the scale
Default Removing tranny from motor ?
Hey well I just pulled the motor out of my civic, d series of course. I took off 4 (i think) 17 mm bolts holding the tranny to the motor, is there anything else holding it together?
forsakened is offline   Reply With Quote
Old 07-24-2006, 09:57 PM   #2
99sidude's Avatar
Ride:  gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
Rep Power: 50 99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of
Send a message via AIM to 99sidude
Gallery
There are a bunch of helms manuals for hondas in that link. Personally, I would just loosen all bolts that look like they conect the tranny case to the block (just use common sense).
99sidude is offline   Reply With Quote
Old 07-24-2006, 10:10 PM   #3
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Make sure to remove the starter too- then rock the transmission back and forth to break it loose. You might be able to find a few points along the side to use a pry bar with.
Old 07-24-2006, 10:22 PM   #4
99sidude's Avatar
Ah yes now I remember what a bitch it was on my b18c. My friend and I fought with that thing for atleast 10 minuts before we got a gap big enough for a screwdriver.
Old 07-25-2006, 12:07 PM   #5
I didnt take the starter off, so Ill go do that and see how it goes.
Old 07-25-2006, 01:45 PM   #6
Ok, well that was fun enough. Got it off but now new problem.
How do you remove clutch/flywheel and swap to new motor?
Old 07-25-2006, 04:59 PM   #7
VTECin5th's Avatar
Rep Power: 41 VTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of light
Send a message via AIM to VTECin5th
With a 10mm 12 point socket and a 17mm 12 point socket.
Put a screwdriver inside the small holes in the flywheel so it will pry up against the block to prevent the whole thing from spinning.
k20dc5
VTECin5th is offline   Reply With Quote
Old 07-25-2006, 05:20 PM   #8
Alrighty, I guess I need to go to advance or something and get some 12 points...
Old 07-26-2006, 03:09 AM   #9
Rep Power: 14 divisii is off the scale
Holy cr* thanks for the link, I just posted on similar subject. Thx.
1999 Civic DX--
AEM CAI, Magnecor plug wires, 195-50/15x7 alloys
future? B or K swap
divisii is offline   Reply With Quote
JDM GSR motor w/ auto tranny, motor mount problems balkey HYBRID -> EG-EK / DC 4 10-30-2008 09:08 PM
1996 1.8 ls motor no tranny f/s bluhatch95 Parts: For Sale/Trade/Wanted 42 10-11-2005 10:53 PM
2000 D16 VTEC motor and tranny w/ JR SC jabcivic Parts: For Sale/Trade/Wanted 12 11-22-2003 02:58 PM
selling my tranny but cant get it off the motor... b18vtecrx General Tech and Maintenance 7 11-06-2003 03:09 PM
