This is a discussion on Shift Linkage Giving Me Grief in the HYBRID -> EG-EK / DC forum
Hi Ladies and Gents, I am almost finished with my b20b/b16a swap into my 2000 civic ex. I have a few questions:
1. To start off, I bought a GSR transmission from a shop for a good price. The catch was that one of the ...
| | #1 |
| Hi Ladies and Gents, I am almost finished with my b20b/b16a swap into my 2000 civic ex. I have a few questions: 1. To start off, I bought a GSR transmission from a shop for a good price. The catch was that one of the rear-mount holes on the tranny was broken, so the shop had a machinist re-weld it. The weld was straight and looked good, but he did not drill or tap a new hole for the bolt to go into. I took the transmission to a local machine shop that would drill and tap the hole for the best deal. Well, I got what I payed for and they made a new hole that would fit, but was still a little off, as in it was at a slight angle. When mounting my motor, I noticed that the angle of the bolt made the rest of the mounts a little off-center. Basically, when I mounted the rear T-bracket, the upper and lower tranny mounts were slightly off. This caused a lot of grief, but I was able to finish it. The transmission to block bolts all lined up except one right above the rear T-bracket and below the thermostat housing. Now the motor seems to be sitting and the area where the tranny connects to the block seems to sit a little higher than everywhere else. After the story of my life (sorry about that), my question is could the slight difference in angle affects how my shift linkage goes on? I am trying to put it on now but for some reason I can't get it to fit. I'm hoping that I am assembling it incorrectly. Can someone please put up pictures on what a correctly installed shift linkage looks like? Theres more.. 2. I'm putting a b20 into a 2000 civic (obd2b). I have arrived at the distributor issue (mine is obd1, can't afford to buy a new one). I have researched and am going to attempt it soon. My question is instead of constructing a jumper harness, could I just wire the OBD1 plugs directly into the Engine Wire Harness? If so, would that be an easier route? Sorry for the novel guys. |
| | #2 |
| I have a hunch that the back of the transmission is angle up to the point that the U-joint of the shift linkage does not have room to move around when connected. |
| | #3 |
| any chance you could open up the hole on the mount itself so the bolt doesnt sit on it so much? |
| | #4 |
Similar Threads | ||||
| What is the difference between 94+ Integra shift linkage and the 95 civic linkage? | UNDR8D | HYBRID -> EG-EK / DC | 8 | 10-16-2007 10:58 PM |
| shift linkage Shift cable? | Ignorant import guy | HYBRID -> EG-EK / DC | 3 | 02-04-2006 10:14 AM |
| shift linkage | daidilus | HYBRID -> ED-EF / DA | 6 | 02-22-2004 07:47 PM |
| shift linkage? | Vtec Andy..... | Engine Building | 1 | 11-08-2003 05:10 PM |
| shift linkage | h22bubbleback | HYBRID -> EG-EK / DC | 8 | 08-09-2003 01:26 AM |
