shifter doesnt sit right
Old 09-21-2006, 11:18 AM   #1
Rep Power: 0 theguy is on a distinguished road
Default shifter doesnt sit right
I swapped a '95 B16SiR into my '99 EX. My problem is that the stock EX shifter now sits well forward of where it was (towards 1st 3rd and 5th), and when i shift forward the stick butts up against the center console. The guys who performed the swap told me the bushing on the stock shifter was shot and replacing it with an aftermarket or stock Del Sol shifter would solve both of these problems. My question; is the difference in shifter angle common with this particular swap, and which shifter would best alleviate this situation.
theguy is offline   Reply With Quote
Old 09-21-2006, 12:12 PM   #2
Führer Mod
eg6sir's Avatar
Ride:  Le Car
Rep Power: 366 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
i'm guessing the shifter is turned around the wrong way..
DO NOT PM ME WITH TECH QUESTIONS!
XGT: cEElint
Originally Posted by 93civicracer View Post
my dad owned a Chevelle with a hemi that he claimed made 600hp.
eg6sir is offline   Reply With Quote
Old 09-22-2006, 08:42 PM   #3
Ride:  93DX B16A ODB2 p30
Rep Power: 7 DarkElfTRP is on a distinguished road
I am getting the same thing on mine, what a pain to shift into 5th
DarkElfTRP is offline   Reply With Quote
Old 09-22-2006, 08:45 PM   #4
Führer Mod
eg6sir's Avatar
Ride:  Le Car
well.. does the shifter bend forward or backward.. its supposed to bend back, if it doesnt its probably turned around.. seen it before, thats why i say this..
XGT: cEElint
Old 09-22-2006, 09:10 PM   #5
Cannot really tell since the boot is in the way, however there is a TON of play in mine if you did not know the car you would think its in N
Old 09-22-2006, 09:11 PM   #6
Führer Mod
eg6sir's Avatar
Ride:  Le Car
you should be able to tell whether its leaning forward or backwards
XGT: cEElint
Old 09-23-2006, 05:39 PM   #7
Thanks for the replys. It definitly was turned the right way. I tried to install the ss I had and just to see I turned the stock one 180 and the result was much further foward than it was already. The ss seems to have taken care of the shifter hitting the front of the housing, but it still doesnt seem right. Mabey the new shift linkage is a little longer than stock EX?
Old 09-24-2006, 07:34 AM   #8
VTECin5th's Avatar
Rep Power: 41 VTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of light
Send a message via AIM to VTECin5th
You need B series (NOT DEL SOL) shiftlinkage.
94+ integra will work.
99-00 civic Si will also work.
k20dc5
VTECin5th is offline   Reply With Quote
Old 09-24-2006, 06:25 PM   #9
tip
Rep Power: 13 tip is an unknown quantity at this point
sounds like someone put as smaller bolt and nut in the end unstead of the correct pin. replace it with the right pin or a new pin and that will fit it
tip is offline   Reply With Quote
auto to manual conversion d112crzy HYBRID -> BA-BB /CA-CD 0 09-13-2006 11:27 AM
SHORT SHIFTER HELP!!! evo8 General Tech and Maintenance 8 04-04-2005 04:18 AM
Transmission Problems With Skunk2 Short Shifter MaaseyRacer General Tech and Maintenance 3 12-06-2003 03:12 PM
short shifter problems aphex301 General Tech and Maintenance 14 10-08-2003 12:46 AM
SHORT SHIFTER FOR GSR &/or 00' SI linkage chingro Parts: For Sale/Trade/Wanted 0 09-28-2003 12:51 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
