skunk 2 cam gears on ctr cams
Old 09-26-2007, 03:01 AM   #1
Rep Power: 0 skibum853 is on a distinguished road
Default skunk 2 cam gears on ctr cams
swappin in a b16b. put skunk2 cam gears on the ctr cams. now im just trying to get it time. right now it seems like the cams are opening cimpletely backwards (i.e. intake valves opening when exhaust valves should be.) anyone have any idea what all the diferent marks on the skunk2 cam gears mean and which ones should be streight up? on each cam gear there are three marks on the teeth. one tooth has a dimple. 90 degrees from that is a white line with a circle, and 180 degrees from that is another white line with a circle. so confused.
skibum853 is offline   Reply With Quote
Old 10-14-2007, 06:51 PM   #2
Rep Power: 5 JWL54 is on a distinguished road
are you sure youre rotating the engine counter clockwise? that could be your problem with the intake valves opening when you think the exhaust should be. as for the skunk2 gears im not sure.
JWL54 is offline   Reply With Quote
Old 10-14-2007, 07:36 PM   #3
Honda Master Technician
norcalgsr's Avatar
Ride:  88 Prelude Si and a CBR 600 Hurricane
Rep Power: 21 norcalgsr is a jewel in the roughnorcalgsr is a jewel in the roughnorcalgsr is a jewel in the rough
myspace
If I remember correctly the dimple should be straight up, and the other two white lines are reference marks for setting the valve lash. If you put both the dimples straight up and align the white marks in the center (the gap between the two cam gears) even with each other, then they should be set properly.
Hope that helps..
norcalgsr is offline   Reply With Quote
B Series Cam Guide JDMilan Reference Materials 35 04-13-2007 09:26 PM
Wtb Vtec Head ls ef Parts: For Sale/Trade/Wanted 6 11-09-2006 04:21 PM
skunk 2 cams and gears pistonkiller Engine Building 6 10-16-2006 11:48 AM
Build a Reliable LS/VTEC hondacrxb16vtec General Tech Articles 0 10-06-2006 08:54 PM
How to build a "reliable" lsvtec/b20vtec bambam General Tech Articles 2 07-02-2006 05:48 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
