Swap help, 93 del slow with 2000 gsr
Old 06-26-2003, 04:10 PM   #1
Rep Power: 14 itsbigmike is off the scale
A buddy of mine is swapping a 2000 gsr into his del slow, and needs some help that's beyond me, and quick
1. First off, what is the rear mount bracket used for a b-series swap into a 92-95 civic
2. He wants to use his obd2 computer, so is there a harness to go from the obd1 harness in the car to plug into the obd2 computer? I think they make the opposite, but I'm not sure about using the obd2 computer. If there's no harness, is there a wiring diagram for it somewhere or anything?
Thanks a lot
Mike
itsbigmike is offline   Reply With Quote
Old 06-26-2003, 11:55 PM   #2
Rep Power: 0 H22AEG2 is off the scale
There isn't a bracket that you need. You just need the B-series mounts. The harness to plug in the different OBD series can be purchased from www.hasport.com
Oh, and PLEASE don't call it a del slow. I have seen plenty of damn fast del Sols.
Good luck with the swap!
H22AEG2
<a href=\'http://www.teamsolfl.com\' target=\'_blank\'>Team Sol Florida</a>
Event Coordinator
H22AEG2 is offline   Reply With Quote
Old 06-27-2003, 02:39 AM   #3
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
use the stock b-series mount that came on the motor for the rear mount
don't use the obd2 ecu. it has an imobilizer built in to it, and is worthless without the same car's ignition system. in otherwords, no matter how bad he wants to use it, it wont work.
buy an obd1 p72, and it will plug right in to your car. you will have to do one wire change.... http://www.hondaswap.com/swap/viewer.php?id=51
Old 06-29-2003, 09:59 AM   #4
I've seen fast del sols, I just call this one a del slow cuz its my boy and it pisses him off. He has the hasport kit, and supposidly he's sending his p28 out to be reprogrammed to work with the gsr =\
I told him to just find an obd1 type r ecu on ebay or something but he don't listen
Kinda funny when mechanics think they know it all
But yea you do need the rear motor mount bracket that came with the engine it turns out, the civic/del sol one is at a different angle or something so it didn't line up
Thanks for the help
Old 06-29-2003, 11:39 PM   #5
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 541 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
they dont exist
now whats this about "know it alls" ????
ITR came out in japan in 96
ITR came out in the US in 97
either one of those are OBD-2 years
an ITR ECU will not control the secondaries ... so unless he has swapped the intake manifold with one that doesnt use them the ECUs wont work for him
МОΛΏΝ ΛΑΒΈ
2000 Civic Si Engine Swap KillerTypeR HYBRID -> EG-EK / DC 4 10-21-2003 08:39 AM
Type R(obd2a) swap Into a 2000 Integra Gsr(obd2b) gsr-t- HYBRID -> EG-EK / DC 3 10-14-2003 09:44 AM
2000 type r into 95 civic coupe dx Johnnylawless HYBRID -> EG-EK / DC 7 10-07-2003 01:23 PM
What Is Needed To Swap 2000 B18c Into 98 Hatch 1phathatch HYBRID -> EG-EK / DC 1 03-05-2003 05:44 PM
Swap B18c5 in Honda civic 96 hondacivicnos HYBRID -> EG-EK / DC 1 12-19-2002 10:17 PM
