Swap Problem....Won't Start
Old 08-10-2003, 09:45 PM   #1
jl21ah is off the scale
Send a message via AIM to jl21ah
Thumbs down
Alright, tough damn day today. Got my b18c1 into my 96 ek today. Used 96-98 ex wiring harness, running obd2 p72, but the !@#$ won't start. It tries to, but won't turn over. What the hell is going on? The engine ran fine in my EG. I am throwing IAT code 10 if that says anything. I wired the CKP(crank) and 2nd o2 and everything, but it just won't start. I checked the spark plugs and it wasn't wet, so, I don't know if gas is getting inside the cylinder....could this be a wiring issue? (injectors not receiving signal?) Any body else have this prob? It's a 99 motor...
ARGHHHHH...
Please HELP!
95 VX + 96 Midori B18c1
jl21ah is offline   Reply With Quote
Old 08-11-2003, 11:00 AM   #2
darwins_vtech is off the scale
Send a message via Yahoo to darwins_vtech
does it sound like it has compression? does it just whin, almost like a whistle? then it might not have compression. otherwise make sure that you let the fuel pump run for 10 sec before trying to start the car. That way it gets fuel all the way into the motor. good luck
Darin
darwins_vtech is offline   Reply With Quote
Old 08-11-2003, 10:12 PM   #3
it started today...dont know what the hell it was, maybe loose wire or something, cause i re did all my extensions...might have been misfiring too, cause i went back and re did all the spark plug wires and shit....it starts now!
Intermittent cold start problem? preludude General Tech and Maintenance 8 05-18-2004 10:08 PM
Head gasket... won't start now.. HELP!!!!! ckyhimself HYBRID -> ED-EF / DA 4 01-09-2004 08:06 PM
90 Civic HB that won't start starboy869 General Tech and Maintenance 18 12-29-2003 12:23 PM
after swap car won't start civic00gsr HYBRID -> EG-EK / DC 7 08-20-2003 07:27 AM
2000 Ex Won't Start Jeef General Tech and Maintenance 8 01-19-2003 09:14 AM
