Swapped A D16z6, No Fuel Injector Pulse?
Old 06-06-2003, 07:22 AM   #1
Sinner is off the scale
I did a swap and it was idling while about 30 minutes. To check for leaks. Anyway then I hooked up the throttle cable to and tried to adjust the tps sensor. Well when I hit the gas it would bog and finally it bogged and died. Now when I try to crank it Its not sending fuel. I know its has fuel pressure since I hook the fpr off and cranked which sprayed fuel everywhere. Then I tested the injectors buy manually turning them on and they worked. So i think I'm not getting a fuel injector pulse. Is there anyway to test for this? Anyone have any idea whats going on and how to fix it?
Nick
Sinner is offline   Reply With Quote
Old 06-06-2003, 08:10 AM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
pissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to behold
what did you sawp the z6 into?
Drag kit install manual pissedoffsol Forced Induction 0 07-17-2004 11:37 PM
research paper, what do you think? 90 accord Members' Lounge 9 06-22-2004 11:11 PM
just swapped...no fuel... rtpassini HYBRID -> EG-EK / DC 4 05-31-2004 11:21 AM
Fuel system Sed8ed Engine Building 2 05-26-2004 12:05 PM
1st Gen CRX FAQ's pissedoffsol Swap Articles 0 01-12-2004 12:51 AM
