Swapping B18B into EK but....
Old 10-28-2009, 09:33 PM   #1
Greenhorn
Ride:  EK
Rep Power: 0 misir00 is on a distinguished road
Default Swapping B18B into EK but....
Hi
i own a 1996 Honda Civic hatchback and i would like to swap in my b18b1 out of my 1990 Acura Integra LS into my civic.
I know about all the mounts and linkages and everything but what about my wiring, and whats this obd0 to obd2 conversion im going to need?
misir00 is offline   Reply With Quote
Old 11-05-2009, 12:38 AM   #2
Rep Power: 0 intenseneal can only hope to improve
Ok if you are swaping a B18b1 its from a 94-01 Ls the 90-94 Ls had a B18a1 and is obd1. Check the block for B18... stamped on the block, its by the exhaust mani on the left side ( looking at the car). If it is a B18b1 then you need to find out if its obd1 or 2. 94-96 was obd1 and 96-01 was obd2. As for the wiring contact Hasport or go to ff-squad.com for wiring info and how to. Swapping in an obd2 motor will be much easier. I just did a 99 B18b1 into my 98 Hx, it was way easy. ff-squad.com and Hasport really helped me get the wiring right the first time around.
intenseneal is offline   Reply With Quote
92 EG with B18B swapping in 97 B18C1 CRXratedR HYBRID -> EG-EK / DC 1 06-01-2008 06:44 PM
B18b swapping questions jtornado HYBRID -> EG-EK / DC 5 05-21-2007 12:31 AM
swapping a zc sohc dual carb for a b18b bill blackburn Integra 0 02-20-2007 08:25 PM
swapping the b18a or b18b into the hatch Slammed90Lude HYBRID -> EG-EK / DC 4 01-22-2004 04:22 PM
Swapping Hub From 4-lug To 5 Drock42 Wheels / Suspension / Tires / Brakes 1 01-13-2003 11:07 PM
