Has anybody accomplished this or know of any good info on the web. I found a place nearby that will sell me a JDM B16A for cheap and was wondering what version I should look for so that the install is the easiest for me. How would the OBD ver affect me with this?
You'd be better off sticking with the LS over getting a b16...or you could get a GSR :P
Brett <img src=\'http://nrg-racing.com/images/dv8/aj/dv8_logo.jpg\' border=\'0\' alt=\'user posted image\'> Juiced 97 CGP TEG GS What I have noticed is people who say nitrous is bad, nitrous sucks, blah blah blah. But they don't have technical information to back it up...."its just cheap".....well hmm. If I spend less money than you, and am way faster, who's the smart one? |
integra's are heavy, and with a 1.6 you'll have no torque.
go ls/vtec, or find a gsr swap. __________________
<a href=\'http://www.geocities.com/coker_boy/honda.html\' target=\'_blank\'>The Green Machine</a> |
#5 |
GNU/Linux Evangelist
Ride: The Cheapest Road Bicycle I could get
You have the LS bottom end already, an LSVTEC is a viable solution.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com |
#9 |
Your 92 is OBD-1, depending on what B16 your getting, I would try and stick with OBD-1 (Square Plugs) ,OBD-0 (Round Plugs) is going to be a little more of a wireing nightmare. Nothing plugs right up other than a couple of sensors...........
Juiced LS.............mmmm |
#10 |
It could very well be OBD0 some of the 92's were.
#11 |
the ls transmission sucks for all motor. plan ahead and piece the setup together. you'll need a cable transmission, ls/gsr bottom end, vtec head. any vtec head will work, you just need an obd1 distributor and obd1 injectors. plus, you'll need someone to put it all together.
#12 | |
#14 |
That is correct. If your car has grey plugs for the distro it is OBD1.
#15 |
right i had a 92 teg and put a JDM B16 in it and it haulled A$$...vtec is a world of a diff. if you get a pre obd motor all you have to do is change the dist and the injectors make sure that you get the PR3 ecu and a J1 tranny some say that the YS1 is the better tranny for that car but i know the diff I know what that car is supposed to do and what it will do so you are shaving some weight with the new B16 and the car does move....I ate many a mustangs with that car and i miss it every time i see one of those apc hos so yes go with the B16 you are gaining about 40 hp with it so it is up to you good luck
![]() __________________
RIP Craig Anthony Darce 17 May 2002 |
#16 |
If you want VTEC go LSVTEC. Built right it will own a teg with a B16.
#17 |
the crvtec is better than the lsvtec i have seen it done the only problem with frankenstein motors are that they are not an original product of honda and there is no telling what kinda problems you will have
#19 | |
Member of the 20 nut club
if you already have the B18 and want to be 2.0 that bad just get the thing re-sleeved__________________
МОΛΏΝ ΛΑΒΈ |
#20 |
learning in progress
Ride: 00' Montero sport, 99' lsv civic
look guys, remember some facts before considering LS/V, first reliability is gone , too much R/S is bad... if the car is not going to be a daily driver then great!!! do it...if not save your hard earned money and go for a b18c/5-R or ...buy the b16a buy: sunk2 ecu, cams(your choice), gears, port polish head, match intake man..throttle body. 4-2-1 header, test pipe... 75 wet No2 syst and then post again, remember loos as much weight with out comfortabillity...
#21 |
RETIRED
holy fuck.
THIS THREAD is a YEAR, an FUCKING YEAR old. then, kindly take your head out of the internets ass that says the r/s ratio is too bad. jesuse christ |
#22 |
RETIRED
Bringing dead threads back for the sake of adding zero value comments is a bad thing. Please refrain from doing so in the future.
Thread locked to prevent further post whoring. ![]() |
| zc swap into 85 crx? | devnjeff | HYBRID -> ED-EF / DA | 4 | 07-10-2005 11:09 PM |
| fs ls b18b b16a DA integra civic cx parts | lshatchcx18 | Parts: For Sale/Trade/Wanted | 11 | 03-17-2005 05:49 PM |
| B16A Variants | pissedoffsol | Swap Articles | 0 | 01-12-2004 02:31 AM |
| 1st Gen CRX FAQ's | pissedoffsol | Swap Articles | 0 | 01-12-2004 01:51 AM |
| 94 Integra Ls auto w/ b16a sirI swap | aznbadboyz215 | HYBRID -> EG-EK / DC | 0 | 06-30-2003 12:46 PM |
