Facebook Twitter
Throwing CEL
This is a discussion on Throwing CEL in the HYBRID -> EG-EK / DC forum
Hey I am getting a code 14-IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor and a code 41-Primary Oxygen Sensor - Heater circuit malfunction. After I replaced my P05 ecu in my 94 hatch with a P28 so that I could ...
Old 10-11-2004, 09:30 PM   #1
Hey I am getting a code 14-IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor and a code 41-Primary Oxygen Sensor - Heater circuit malfunction. After I replaced my P05 ecu in my 94 hatch with a P28 so that I could run vtec. I have already ran all my vtec wires and now when I try and run my car it is extremly loppy and will die. 14, and 41 are the codes my CEL is throwing. Any help on what I should do? Also I have a 1 wire O2 sensor right now do I need to run it diffrently with the D16Y8 with a P28.
<span style=\"color:green\">94 Cx hatch /w B16 Sir II -
preping for tracking this summer.</span>
Teal_HB is offline   Reply With Quote
Old 10-12-2004, 03:04 PM   #2
xj0hnx's Avatar
Yes, you have to rewire to the four wire o2, there's a how to in the articles section. In the same one, there is a link to the IAC fix.
xj0hnx is offline   Reply With Quote
Old 10-14-2004, 02:55 PM   #3
I could not find the link you are talking about. I was also wondering if the IAC sensor was working fine when I had my P05 ECU in and now that I have put my P28 in, if maybe it was because it needed to be wired to diffrent pinouts on the P28. Could this be and if somone could post this link that would be nice. Thanks
Old 10-15-2004, 11:59 AM   #4
pissedoffsol's Avatar
http://www.hondaswap.com/forums/inde...howtopic=33248
Old 10-15-2004, 02:48 PM   #5
Actually I have accomplished getting a new 4 wire O2 sensor and wiring if correctyl to my ECU. Now my problem is that I am getting a code 14 which is the code for malfunctioning IAC. That is what I was wondering if anyone had any advice on fixing.
© 2001-2013 HondaSwap.com
