Is a 1993 Del Sol tranny hydro? If so will it bolt up to a B18B1?
Also Is a 1997 Del sol tranny hydro? If so will it bolt up to a B18B1? P.S. i know it depends on the trim model...But is there a Del Sol tranny that is out of a 1993 that will work? And is there a Del Sol tranny out of a 1997 that will work? |
1993 Del Sol is Hydro tranny.
1997 Del Sol hydo tranny!! B18B1 yes if its from a B Series Motor. I don't quite get what you are asking but hope above helps... check out the references made on Honda swap and articles read and searching is the key!!!! __________________
91 STD Hatchback With OBD1 JDM Motor YS1 JDM tranny!!! PR3 OBD1 ECU and Dizzy TD-44U. 92-93 XSi **JDM** Stock Motor ECU and Engine Harness Converted to OBD1. Vtec Currently Working :O <a href=\'http://members.aol.com/megabighulk/Dyno1\' target=\'_blank\'>http://members.aol.com/megabighulk/Dyno1</a> My Dyno ^ |
if the Del Sol has a B-series motor(Del Sol Vtec) than the tranny will bolt up to any B-series motor that uses a hydro tranny. To get more specific, the tranny should work fine with any B18 as long as it is 1994 and up. I think that should answer your question.
"let those who judge me burn in hell until their Hondas are repossessed" - ME 1.6-1.8 |
| cable and hydro tranny | jinstuh | Engine Building | 2 | 02-04-2004 11:15 PM |
| f/s Cable LS tranny and Cable to hydro conversion | dwn2low | Parts: For Sale/Trade/Wanted | 2 | 09-09-2003 05:13 PM |
| Want to trade hydro tranny 4 cable | swapdohc | Parts: For Sale/Trade/Wanted | 0 | 07-10-2003 09:50 PM |
| hydro tranny / cable clutch | lovinhonda | General Tech and Maintenance | 2 | 06-29-2003 01:41 AM |
| Hydro Clutch Cable Tranny | b16a91crxsi | HYBRID -> EG-EK / DC | 2 | 12-29-2002 01:12 PM |
