Tranny question...00 B18C1
Old 07-19-2003, 12:50 PM   #1
Rep Power: 14 RiceBurner98SC is off the scale
Thumbs up
What could cause a tranny to pop out of gear by itself? Meaning, through all the gears theres no problems, no grinds, and its smooth. All of a sudden, when I put it into 5th and ride at about 60mph a few minutes later it just slides out of gear. When I put it back into gear theres no problem but when I hold onto the shifter for a few minutes, I can feel the small amount of pressure of the shifter trying to push out of gear. Could it be a mount not bolted down or maybe the shiftlinkage? Or a problem internally. Tranny has only 27k miles.
1994 Acura Integra
00 B18C1
DC Sports Header
99 GSR Complete Black Interior
-Updated-
Spun Bearing
Trashed Crank
-Future Mods-
Working Motor
RiceBurner98SC is offline   Reply With Quote
Old 07-20-2003, 12:53 PM   #2
Bad syncro maybe?
1994 Acura Integra
00 B18C1
DC Sports Header
-Updated-
Spun Bearing
Trashed Crank
-Future Mods-
Working Motor
Old 07-21-2003, 02:44 PM   #3
Rep Power: 16 omega11855 is off the scale
i had the same problem except mine scrapped a little when i took it apart the whole top assembly was burned out so i put a new 5th gear and and everything above it the bearings where fried actually i overhauled the whole tranny but its popping out cause its either fried or the synchro is toast ur gonna have to open it up
"Girls are like cars u can have as many as you can afford but you can only drive one at a time"~Me
<a href=\'http://www.jzperformance.com\' target=\'_blank\'>Jz own meee</a>
omega11855 is offline   Reply With Quote
Old 07-25-2003, 07:43 PM   #4
Rep Power: 15 jNYCe5 is off the scale
My brother had the same problem w/ his b16 in his ef hatch. It would pop out of gearin fifth. We checked the trans fluid and it was almost empty. Pass side axle seal was no good so we replaced that, filled up the tranny and it never happened again. It does whine in 4rth gear now though, maybe a bearing is not to good anymore.
Hope that helps, good luck
jNYCe5 is offline   Reply With Quote
tranny question Drenni General Tech and Maintenance 1 02-19-2004 09:19 AM
one stupid tranny question kingmarc63 HYBRID -> BA-BB /CA-CD 3 11-30-2003 07:26 PM
tranny question darwins_vtech HYBRID -> EG-EK / DC 1 08-05-2003 10:59 AM
Tranny Linkage Question deth101 HYBRID -> EG-EK / DC 4 05-30-2003 05:28 PM
B16a2 With A Cable Tranny Question ventolin5 HYBRID -> EG-EK / DC 6 02-20-2003 09:21 PM
