turbo b20 vtec
Old 07-22-2004, 04:19 AM   #1
Rep Power: 0 td-civ is off the scale
i am doing a b20 vtec on boost the bottom end is biult but im using the stock sleeves with a block guard i have a safc and a inline pump and a full msd setup and im going to us dsm 450's
how much boost do you think i can run
td-civ is offline   Reply With Quote
Old 07-22-2004, 08:30 AM   #2
Rep Power: 13 twisted civic is an unknown quantity at this point
depends on what "built" means - all forged internals?
either way, stay a little on the safe side, you may not make huge power but at least it'll stay alive.
mildly built should be good for 15 psi and still live a long life.
twisted civic is offline   Reply With Quote
Old 07-22-2004, 10:47 AM   #3
Rep Power: 16 mrnice1058 is off the scale
Send a message via AIM to mrnice1058
15 psi if you are going to leave it with the stock sleeves but don't leave it at 15 psi if you are just driving around town lower it to like 8 psi then push it up when you are going to race
started but running pretty rought have any advise pm me and let me know!!
mrnice1058 is offline   Reply With Quote
Old 07-22-2004, 11:11 AM   #4
low boost setting - 7psi
medium boost setting - 12psi
high boost setting "race fuel and track" - 15psi
that is what I would stick to..
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 07-27-2004, 04:08 AM   #5
the motor has je pistons and crower rods block guard and the head is p&p and im using arp head studs and i will be running gsr cams soon
thanks for your help i was thinking of running 6 psi on the street and 15 on the track sweet 12's here i come
Old 07-27-2004, 12:37 PM   #6
Rep Power: 0 turbodx is off the scale
Thumbs up
I just completed a similar setup , I'm in the process of installing a Z10 crankcase breather. Can anyone tell me what size allen key to use on the 2 allen screws on the back of the motor, to remove them.
turbodx is offline   Reply With Quote
Old 07-28-2004, 02:41 AM   #7
why you want to do that
Old 07-29-2004, 09:31 AM   #8
Disregard that post I got the answer, it's a 14mm allen key . From my research plus the fact that I see most ppl with B20 swaps doing it , u need the kit to relieve some of the pressure from the crank case. check this link out http://www.theoldone.com/
