Wolf dawg
Ride: DSM awd spyder/civic hb
I am running a type-R with a JDM p73 in my 97cope. I need to know how to tell A JDM p73 to a US p73 and one more thing If I was going to use a GSR p72 or the US p73 what would I need to do to run it with my type-R to pass the OBD2 test
Any info would help out a lot. Thanks Wolfy![]() |
Regular Member w/ Cheese
Ride: 2000 EJ8 w/ SiR-II
well to make it obd2 you'd need an obd2 distributor and obd2 ecu. i couldnt say specifics as i've never converted a motor like this. just read about it.
to make it a stock usdm ecu fuel map, you need to resocket your ecu. the chip would need to be flashed or burned with a .bin file. you can try to find the stock maps on pgmfi.org. resocketing your ecu requires soldering. i use hondata but there are alot of different programs to flash a ecu chip with. read up on pgmfi.org for more detail. i'll throw uberdata, aem ems, crome, and megasquirt out there because everyone loves to shout out the others. pgmfi is your headquarters for ecu socketing. |
Wolf dawg
My car is already OBD2 97cope. The type-R is obd2 but you can not read the JDM p73 with a hand scanner and it will not pass the obd2 test. All I what to know is how to tell a p73 JDM from a US p73. Also If I would use a GSR p72 ecu or US p73 would there any thing I would need to do to make it work With out having any cel come up. Any info on that would help Thank Wolfy
All type r motors are obd2
Got my swap!!! Needs to be faster.
#7 |
Wolf dawg
Yea I am going to try that gsr one first. I looking at a gsr and I only seen one sensor that my type-R don't have. So I am hoping to to wire that one up and make it work.
#9 |
Wolf dawg
Yea I need to pass the OBD2 plug in test. And my old ecu will not run the type-r. I looking for some one that would know what ecu to run and how to wire and trick it up b/c the USDM-R and GSR has one or two sensors that the JDM-R don't have. So anyone out there help me out. And One more thing any one know how to tell a JDM-p73 from a USDM-p73 Thanks Wolfy
#10 |
Wolf dawg
Ok I found some info that will help me with my type-r but I still need one more thing.
All US OBD2 DOHC VTEC ecu’s look for a crank sensor or CKF sensor that is located on the oil pump of US OBD2 B-series engines. JDM OBD2 B-series engines do not have this sensor, hence the reason your motor is missing the CKF sensor. There’s an easy wire mod you can do to trick the US P72 ecu into thinking the CKF sensor is wired in. Here is the thing. If I use a p72 out of a gsr on my JDM type-r and do this trick what els would I need to do to make it run right with out having any cel. Some one toled me that I will have a code for the secondary butterfly. is there any thing els I am missing and how would I trick it? Thanks Wolfy ![]() |
#11 |
drive it like U stole it
Ride: 99 dx coupe y8, 94 ex coupe z6, 89 teg zc,
SYNOPSIS
This article describes how to trick a U.S. OBD2a or OBD2b ecu into thinking a CKF sensor is wired in when there actually is no CKF sensor on the engine. What is the CKF sensor? The CKF is the Crank Fluctuation Sensor. On all 96+ (OBD2) Honda/Acura vehicles, this sensor is integrated onto the oil pump. (CKF images soon) This trick is mainly aimed to help hybriders who are using a U.S. OBD2a/b ecu in their vehicle, but their motors are lacking a CKF sensor. For example, running an JDM OBD2 engine in a US 96+ vehicle but retaining the US OBD2 ecu. For those that don't know, when using a US OBD2 ecu and the CKF sensor is not wired in, the engine runs like total crap. This trick basically taps the CKF into the CKP signal. This wire trick will save you money (around $300) and headaches! PROCEDURE
None. CONTRIBUTIONS / PROPS Special thanks to THIS THREAD on Honda-tech and to the poster omahaturbocivic who exploited this trick!!! |
#12 |
SYNOPSIS
This article covers the 'Code 91' (P-code P0453) issue associated with OBD2 civic and integra vehicles. This problem stems from the type of ecu being used in certain OBD2 civic & integra's. When performing an engine swap on certain 96-00 civic's & 96-01 integra's, depending on what US OBD2 ecu is being used, you may get this pesky code 91 (fuel tank pressure (FTP) sensor) problem. Some 96-98 civics & 96-99 integra's do not have this FTP sensor in the fuel tank which poses as a problem. This partial list below shows which civic & integra vehicles are FTP equipped and non-equipped: Vehicles equipped with an FTP sensor: 1996: Civic EX / D16Y8 (All coupes), Integra GSR & possibly LS 1997: Civic HX D16Y5 (All coupes; California sedan: LX) 1997: Civic LX D16Y7 (California coupe; California sedan: LX) 1997: Civic EX D16Y8 (All coupes; California sedan: LX) 1998: All Civic models 1999: All Civic models(the above list came from a Helms manual) Vehicles un-equipped with an FTP sensor: 1996: Civic DX/CX hatchbacks, Integra RS 1997: ? 1997: ? 1997: ? 1998: ? 1999: CX/DX hatchbacksPretty screwy, eh? This is why there is plenty of confusion on Honda message forums regarding the code 91/FTP sensor. I've seen numerous times people say "The FTP only started in 99" or "None of the '96 models had them". It's all a bit confusing, but there are some solutions for this problem. Read on. SUGGESTED FIXES
There have been reports, that while this fix works on a relatively full tank, empty tanks seem to trigger a code. Even though you've now provided the input, sometimes the ECU looks for a change in that input and you're providing something constant now. CONTRIBUTIONS / PROPS Special thanks to Honda-tech members EE_Chris and Trey (Sullivan) for providing these handy fixes! |
