Facebook Twitter
using lots of coolant
This is a discussion on using lots of coolant in the HYBRID -> EG-EK / DC forum
Alright heres the story, i had my 93 civic cx and it started overheating one night. So then like a week later i was driving and i think it blew a head gasket cause white smoke started pouring out and it just shut off and ...
Old 08-12-2003, 08:59 PM   #1
Alright heres the story, i had my 93 civic cx and it started overheating one night. So then like a week later i was driving and i think it blew a head gasket cause white smoke started pouring out and it just shut off and would not start. So i decided to swap in a b18b since i was going to anyways just not right then. But anyways once i got the engine in, i dont see any leaks but the car seems to be going through a lot of coolant and i can smell coolant when i am driving sometimes. The new engine hasent overheated or anything i just cant figure why it is using so much coolant.
Thanks for any help.
Ben
Whatup Bishes!!
lswhitecivic is offline   Reply With Quote
Old 08-14-2003, 11:42 AM   #2
it seems like i can only smell it inside the car not under the hood as much.
Thanks for any help i dont want what happened to my last engine to happen to this one
Ben
Old 08-14-2003, 05:24 PM   #3
Coolant does run inside the car to the heater core, check that out.
Milan
Old 08-14-2003, 05:37 PM   #4
checked that out and it is leaking at the two hoses that go through the firewall to the core. What must i replace to fix this problem. Can i replace the pipes that go to the core( is that the big black thing behind the center console). One of those hoses was leaking in the engine bay right after the swap, the hose seems to not connect to the firewall very well.
Old 08-14-2003, 10:23 PM   #5
are the ports that those hoses plugged into not in good shape, or is it the hoses.
After my engine swap, I had a hose that was all soft and mushy that I had to replace, make sure the ends of your hoses arent all torn up. If they are and you have enough length, just cut off the bad portion and reattach.
good luck
fook is offline   Reply With Quote
Coolant under driverside floormat zman HYBRID -> EG-EK / DC 3 06-06-2004 11:48 AM
Coolant missing- where did it go? steelbuster General Tech and Maintenance 15 12-04-2003 08:59 PM
coolant bubbling over inspecta83 General Tech and Maintenance 0 09-12-2003 10:13 PM
Coolant temp sensor issues LS/VTecEF9 General Tech and Maintenance 2 07-30-2003 06:08 AM
Coolant Lines? b18vtecrx Forced Induction 6 04-01-2003 02:37 PM
© 2001-2013 HondaSwap.com
