GT5 FTW
Ride: 93 civic hatch
Ive got a 93 civic CX with a b18c1 in it with a Vafc2. Recently i noticed that the RPM display on my vafc is acting a bit strange. the way it goes is at about 750 RPM, at idle, it displays correctly. But at about 2500RPM the vafc displays 3200. However, when the car hits vtec at about 4400 (i changed it on the vafc) the two RPMs match up. as well as when the car hits the rev limiter.
I just thought that it may be possible that this could be affecting the RPM reading my ECU is getting and may be messing with my air fuel ratio which according to a friend who was driving behind me it is really rich and gives off the richness smoke when it is given gas. Also what is strange, i posted this before, but once the engine warms up it cannot hold a steady RPM, it fluctuates plus or minus 100RPM. It runs smooth as butter when it is cold, but progressively gets worse as it warms up. Could my oxygen sensor be bad? P.S. I have not touched the fuel map with the VAFC, i was waiting to get a wide band for that. Thanks, Daniel |
Running on two cylinders
Ride: 2000 Mitsubishi Lancer RPW E5 Coupe
make sure your VAFC is SOLDERED IN.
check to make sure nothing is loose. __________________
Home of the RPW built 2000 Lancer CC Coupe. See what is done to the little Evo5. "If you don't like what I've done with my car, I will gladly refund all the money you put into it." |
B happy
Ride: dohc 95 egg
Well, are you basing the "wrong" RPM on a tach in you car? If so, it's possible the VAFC is correct, and the tach is wrong, OEM tachs can be lazy. Also this can account for the fluctuation you are seeing, the VAFC is reading an signal and displaying it in real time, while your tach may not register it, fluctuations that small aren't abnormal, I don't remember ever seeing a steady RPM on my VAFC, kind of like a A/F meter reading straight off the o2 sensor.
As far as you car running rich, well, you did set vtec pretty low, did you also adjust fuel curves to match? Did you do it with a wideband so it is correct? Well, I just reread you post..that would probably be the cause. __________________
#5 |
GT5 FTW
Ok, since then i have driven it, and i think you are right, i get about 3000 rpms at 60 and the tach is only showing 2200.
As for the vafc, ill check the connections. I soldered them myself, but one may have come loose. Last edited by Dct5289; 04-24-2007 at 05:02 PM. |
