vtec help
Old 09-25-2007, 06:54 PM   #1
gabeybabey
Ride:  92 civic
Rep Power: 5 gabrielaeschliman is on a distinguished road
Default vtec help
I know everyone gets mad when someone asks about vtec but I still need help. If I am converting from non vtec to vtec what are all the wires I need to plug into the ecu manually. I know I need to plug in the vtec pressure switch and the vtec solinoid, is there any other wires. I swaped in a SOHC vtec ZC into my 92 civic lx. I was told to use old engine wiring harness and then manually plug in vtec wires to the ecu. Hopefully there is a way to get my vtec to work without going and buying a whole new harness.
gabrielaeschliman is offline   Reply With Quote
Old 09-25-2007, 08:07 PM   #2
Ride:  2000 si gt40/b18c
Rep Power: 8 honda801 will become famous soon enoughhonda801 will become famous soon enough
Thats everything!
honda801 is offline   Reply With Quote
Old 09-25-2007, 08:54 PM   #3
gabeybabey
Ride:  92 civic
Why the heck wont my vtech work then?
Old 09-25-2007, 08:58 PM   #4
its pinned in the wrong space or you need a new vtec solenoid.
Old 09-27-2007, 01:11 PM   #5
gabeybabey
Ride:  92 civic
Hopefully it's not pinned in the wrong spot. I looked at an OBD1 wiring diagram to see where to put the wires. How do I check to see if the vtec solenoid is working. Can a Honda shop do that?
Old 09-27-2007, 02:00 PM   #6
Mysterious
Ride:  93 Eg Si
Rep Power: 6 N/A b18c1 is an unknown quantity at this point
Did you ever even try testing it or never?
N/A b18c1 is offline   Reply With Quote
Old 09-27-2007, 04:11 PM   #7
gabeybabey
Ride:  92 civic
I am almost possitive it is not working because the engine light is on and there is never a boost of power. The engine is hardly any more powerful than the stock non vtec 1.5L engine that came with my car.
Old 09-27-2007, 05:05 PM   #8
Rep Power: 7 killektiv is on a distinguished road
You can always check for codes. There is a plug above the ECU on the passenger side, it will be a 2 prong plug. You can use a piece a speaker wire if you want. Anything to complete the circuit. Then just watch and count the number of blinks / pauses the check engine light gives you. Then check this thread - Honda-Tech.com: Honda Civic/Del Sol (1992 - 2000): The new CEL thread (includes how-to and codes) for the code translation.
That thread will have pics of the plug Im talking about too. That thread helped me out a lot when I did my swap.
killektiv is offline   Reply With Quote
Old 09-27-2007, 05:13 PM   #9
Now that I think about it - if your car is a 92 then it should have the VTEC wires already. Maybe its different for coupes?
Old 09-27-2007, 09:11 PM   #10
haao13's Avatar
Ride:  boosted sir eg, suzuki gsx750f
Rep Power: 11 haao13 will become famous soon enoughhaao13 will become famous soon enough
this might seem kinda dumb but did you change the ecu?
haao13 is offline   Reply With Quote
Old 09-28-2007, 06:02 PM   #11
gabeybabey
Ride:  92 civic
Yes I changed the ecu.
Old 10-04-2007, 10:43 AM   #12
Lee7pcNOOb's Avatar
Rep Power: 6 Lee7pcNOOb is on a distinguished road
unplug the vtec pressure switch splice the blue wire into the solenoid wire and ground the black wire
Lee7pcNOOb is offline   Reply With Quote
Old 10-09-2007, 01:12 PM   #13
gabeybabey
Ride:  92 civic
So you want me to put the one solenoid wire into the blue wire from the vtec pressure switch. And ground the black wire from the vtec pressure switch.
Old 10-09-2007, 08:22 PM   #14
Lee7pcNOOb's Avatar
no cut off the wires from the vtec pressure switch( be shure to leave enuf room for the wires to be reconnected just incase it wont work) splice the blue wire into the wire going to the solenoid and then ground the black wires somewhere on your chasis. I did this and my vtec kicks harder than a wife hitting the ground at a nascar convention
Old 10-11-2007, 01:01 PM   #15
gabeybabey
Ride:  92 civic
I understand everything you said except grounding the black wires. I only have one black wire and that's on the vtec pressure switch. And if I unplug the pressure switch there are no ground wires left to ground. I was also thinking about when I was plugging both the solenoid wire and the pressure switch wire into the ecu, there were already wires in the slots where I needed to put the vtec wires. So I just unplugged the wires and plugged in the vtec wires. Is that what I should do?
Vtec Solenoid Troubles RandomTask76 HYBRID -> EG-EK / DC 5 05-20-2009 01:05 AM
guaging intrest in selling vtec sub harness kaoskustoms Members' Lounge 30 07-09-2008 01:24 AM
d15b vtec swap questions regal1975 HYBRID -> ED-EF / DA 1 05-24-2006 12:05 AM
Vtec dont want work shifter General Tech and Maintenance 2 04-07-2006 09:45 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
