vtec problem...
Old 11-18-2003, 04:26 PM   #1
Rep Power: 14 hybridracer504 is off the scale
i need a lil help....well here's how it went...i juss finished droppin in the motor and juss got it running....well on the first day u really drive it hard....and on the second day...i did...well i was goin about 40 mph and downshifted to 2 and as soon as vtec was about to kick in the check engine light came on so i got back home and pulled up sum codes....there where 2 codes....21 and 23...can sumone please help me out...thanks
hybridracer504 is offline   Reply With Quote
Old 11-18-2003, 04:29 PM   #2
Rep Power: 19 civic15.8 is off the scale
Send a message via AIM to civic15.8 Send a message via MSN to civic15.8
im guessing you want to know what the codes stand for?
bagged and dragin
civic15.8 is offline   Reply With Quote
Old 11-18-2003, 04:33 PM   #3
if that is what you are looking for the go here http://tech.hybridgarage.com/tech/codes.html
it is the vtec seloniod and the knock sensor either they are unplugged or they are defective
bagged and dragin
Old 11-18-2003, 06:28 PM   #4
Rep Power: 0 B16aJWHO is off the scale
I also get a code 21, but I checked my vtec solenoid and it is still in working condition. Is there anything else that would cause this code to come up? maybe a bad ecu?
B16aJWHO is offline   Reply With Quote
Old 11-19-2003, 12:43 AM   #5
yea...ive checked dat also...and it is workin properly but ive got to check the knock sensor again cuz i havent checked dat yet..and how can i fix dat problem...thanks
Old 11-19-2003, 02:45 PM   #6
Rep Power: 16 darwins_vtech is off the scale
Send a message via Yahoo to darwins_vtech
the car isn't wired for a knock sensor, if it is a OBD1. you have to run a wire from the sensor to the ECU so that it will register, unless you are using an ECU that isn't looking for it. the knock sensor is a single wire plug/bolt that is located on the back of the block, below the intake manifold and by the oil filter. I think it is a green wire most of the time. just run a wire from that sensor along the wire loom to the ecu and Plug it in spot D3 or 4. Not sure. THere shouldn't be a wire in the place though- it should be an empty spot on the ecu harness.
DArin
darwins_vtech is offline   Reply With Quote
Old 11-19-2003, 03:15 PM   #7
bagged and dragin
Old 11-19-2003, 04:48 PM   #8
well...ive checked it and the wire is not green...it is yellow and red...so do i juss do the same procedure dat u told me...thanks
Old 11-19-2003, 05:01 PM   #9
Rep Power: 28 Bl6CRX is off the scale
Send a message via AIM to Bl6CRX Send a message via Yahoo to Bl6CRX
right
Bl6CRX is offline   Reply With Quote
Big problem W/ H22 vtec swap HELP!!! Jason C. HYBRID -> BA-BB /CA-CD 4 05-30-2004 02:37 AM
jdm d15b vtec wiring problem micmac ECU's, Electronics, and Tuning 2 08-29-2003 05:30 PM
Vtec Problem B18CJUNKIE HYBRID -> EG-EK / DC 3 01-09-2003 09:29 AM
