I have a b16a in a 98 ex. My vtec has only kicked in once since I had my swap done. I checked my timing and it was at 20 degrees so I retarted it about 4 degrees. Doing this didnt help. Also, I have no check engine lights. Does anyone have any suggestions I should try? Maybe a new timing belt?
Well, it sounds like it would more than likely be an electrical problem. Double check the wiring to the ecu and check for shorts and opens. You also might want to pull off the vtec solenoid and clean the screen on the inside of it, if it is full of gunk, you won't get vtec to activate properly.
<span style=\'color:red\'>"if i'm happy or i'm sad jack daniel's makes me feel alright raise your glass up hight and we'll sing on and on and on and on" Guttermouth</span> <span style=\'color:red\'>"My long hair just can't cover up my redneck" David Allan Coe</span> <a href=\'http://www.richstevens.com/NAKED.swf\' target=\'_blank\'>Click here for free porn</a> |
B happy
Ride: dohc 95 egg
No CEL? THen how do you know it isn't "kicking in"? The crossover should be smooth.
#6 | |
B happy
Ride: dohc 95 egg
#9 | |
Retired OG
Ride: Integra, Tahoe
.__________________
Kyle I. Collins, PmD. |
#10 | |
2265787829
Ride: Refer to my name, dumbass.
I think I have a new ricer quote. ![]() |
#11 | |
Ride: '92 Civic CX
Garage: 1992 CX Hatch > Current Money Pit Grave: R.I.P. 1995 Integra GSR R.I.P. 1990 DX Hatch R.I.P. 1990 CRX Si |
#12 |
I dont know about you but in my car i can tell the differance in sounds and also if u floor it to like 7200 in 2nd gear and it feels like its not pulling anymore than its not working.
In my car it seemed like it would pull all the way to 5000 or so and then start to lose power a little. It normally should pull to 5000 and then pull way harder to redlline. __________________
<span style=\'color:red\'><span style=\'font-family:Geneva\'>94 JDM H22A|5spd-LSD|GSR Spec Brembo Cross Drilled and Slotted Rotors| GSR Front Calipers| SS Lines|Tokico Illumina Struts| Skunk2 Coilovers| AEM Fuel Rail| ACT Stage 3 Clutch /w Xtreme Pressure Plate| 8lb Kaiten Kairu Super Flywheel</span></span> |
#13 |
my b18c one time (couple actually) waited forever to kick on vtec. I had to wait till it completely warmed up, took forever, then it wouldnt kick on untill late 4000rpms, sometime apeared to be 5grand. I ended up checking the oil, and i was low. changed the oil, and made sure i had enough, and all was good.....
My civic is here www.cardomain.com/id/gsrchad Need rc 720's rims 15-16 with some 205 or wider tires arp head studs for b18c let me know if you have some!!! |
| Big problem W/ H22 vtec swap HELP!!! | Jason C. | HYBRID -> BA-BB /CA-CD | 4 | 05-30-2004 02:37 AM |
| jdm d15b vtec wiring problem | micmac | ECU's, Electronics, and Tuning | 2 | 08-29-2003 05:30 PM |
| Vtec Problem | B18CJUNKIE | HYBRID -> EG-EK / DC | 3 | 01-09-2003 09:29 AM |
