vtec wont work on b16 eg
Old 07-11-2008, 09:31 PM   #1
Rep Power: 6 93y7 is on a distinguished road
Default vtec wont work on b16 eg
i just swapped a jdm b16 into my eg. it didnt come with a map sensor so i t-d into a vacuum line and used my d series. my vtec will not work. i check for continuity through the wires to make sure there is not a break. i triple checked to make sure it was wired right. oil level is full and stays there. what could be causing this. also my knock sensor is not wired. would this cause it not to engage?
93y7 is offline   Reply With Quote
Old 07-11-2008, 09:36 PM   #2
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
myspace
How do you know that it's not functioning?
PSN Network ID: BrutalB83
Old 07-11-2008, 09:46 PM   #3
it slacks off above 6000 rpms. it runs just about a steady pull. and i drove it without vtec until today when i hooked it up and its the same and also it wont go over 115mph at all. my mini me with dx trans and dx intake manifold with 105300 cam would go 127
Old 07-11-2008, 10:47 PM   #4
Brutal Moderator
BrutalB83's Avatar
myspace
So? The gears in a D-series DX transmission are going to be much longer then a B16's transmission. You'll get to 100 mph much faster with the B16 transmission, but the DX transmission is going to be able to reach a higher speed overall. If you want to be able to reach higher top speeds then put an LS fifth in your B16 tranny.
Were you trying to drag race though? What do you need to be going that fast for anyway?
LS/Vtec But Vtec wont work 92CivicLS Engine Building 12 11-11-2008 10:43 PM
LS/Vtec But Vtec wont work 92CivicLS Engine Building 1 01-18-2008 04:38 PM
vtec wont work? 95silverprelude Prelude 28 10-15-2007 05:59 PM
95 prelude vtec wont work 95silverprelude ECU's, Electronics, and Tuning 0 09-18-2007 09:34 PM
vtec wont work odenthall1 HYBRID -> ED-EF / DA 4 07-06-2004 04:08 PM
