What Goes In Easy?
Old 04-18-2003, 05:35 PM   #1
Banned
Rep Power: 0 Moonlight Illusion is off the scale
Thumbs up
Can anyone give me a lists of engines that will bolt into a 1991 CRX DX with out any mods?
Moonlight Illusion is offline   Reply With Quote
Old 04-18-2003, 05:44 PM   #2
Rep Power: 18 EGLSHB is off the scale
Send a message via AIM to EGLSHB
depends on what you call "mods"
with any engine worth swapping, you will have to convert your car to MPFI, since you currently only run 2 injectors,
after that, there are several that will drop in easily
EGLSHB is offline   Reply With Quote
Old 04-18-2003, 06:17 PM   #3
Rep Power: 27 SleEPeR_CRX is off the scale
for a DX u need multi point, then any of these swaps are faily easy, top 1 is easiest bottem is hardest.
Easiest
D16a6( Si engine) 106hp/100 trq $500
ZC(JDM Si)-130hp/103trq $800
B18a(91-93 integra)-132hp/127 trq $2500
B20(CRV engin)-160hp/140 trq $3500
D16y6(92+ Si engine)-125 hp/103 trq Vtec $1500
B16a(JDM SiR)-160hp/111trq Vtec $3500
B18c1 - 185hp/121 trq Vtec ( GSR motor) $4500
B18c5- 195ho/121 trq Vtec ( type R motor) $6000
H22a- 220hp/200trq Vtec ( prelude) it wont fit in a 2nd gen without alot of work tho $4500
Prices are in canadian , and are just roughly what i have seen each COMPLETE swap for.
Sleepers Are the Only way to Go.
1990 CRX Si
B18a(92) CAI/E, Gutted, ACT clutch/pressure plate/13lb flywheel, Crower 403 Cams, Titanium Valve springs & Retainers, Blockguard, Head Milled 20 thou, 9.8:1 Compression, AEM cam gears.
1/4 = 14.73
60' = 2.48
trap = 95.03mph
Soon to get: Header, Slicks
Future 13 second all motor LS!
SleEPeR_CRX is offline   Reply With Quote
Old 04-18-2003, 07:58 PM   #4
Banned
Thanx yo.
any easy swap blngblngskater HYBRID -> ED-EF / DA 15 06-22-2004 11:49 PM
i need 1 damn easy part.... Vtec Andy..... Parts: For Sale/Trade/Wanted 3 01-29-2004 09:32 PM
3 quick and easy questions get_nick General Tech and Maintenance 4 07-21-2003 08:32 PM
Crx Easy Swap DiGiTal66 HYBRID -> EG-EK / DC 15 04-11-2003 03:00 PM
May seem easy to you... Slimtadder Engine Building 10 12-22-2002 01:25 AM
