What Would Be The Best High Horsepower Engine?
Old 04-02-2003, 08:39 AM   #1
Rep Power: 0 94PreludeS is off the scale
Send a message via AIM to 94PreludeS
I have a 1994' Honda Prelude. What would be the best motor swap to do that would have great horsepower ?
- 1994' Honda Prelude Type S
- DC Sports Cold Air intake
- K&N Filter
94PreludeS is offline   Reply With Quote
Old 04-02-2003, 08:43 AM   #2
Ride:  01 is300, 05 s2000, 03 rx300
Rep Power: 57 pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
yea .. i think you should just work with what you've got. perhaps a turbo or supercharger?
pills_PMD is offline   Reply With Quote
Old 04-02-2003, 08:57 AM   #3
I was thinking like a H22 DOHC (JDM) engine. It has 11.0 compression ratio. Is that to much compression to run a T-series turbo from turbonetics? Then i was considering running a 75 horsepower shot Nitrous system
- K&N Filter
Old 04-02-2003, 09:09 AM   #4
you already have a good platform.. just rebuild what you have and boost it, or juice it.
no need to get a "JDM" engine.. it's such a chance thing when you order an engine... what if a ton of shit is broken?? you're out of luck.
i'd say rebuild and boost what you have.
Old 04-02-2003, 10:54 AM   #5
WRX Sellout
Ride:  2002 WRB Impreza WRX
Rep Power: 99 dohcvtec_accord is an unknown quantity at this point
Well, I'm thinking that by his name, he's got a Prelude S, which is a crappy platform for boost. F22A1, SOHC non-VTEC.
You're better off getting a USDM H23A1 to drop in there. No messing with VTEC, nice low to mid compression for boost.
To clarify, the JDM H22A has 10.6:1 compression. The H22A out of the JDM Type S has 11.1:1 compression.
This space left intentionally blank.
Old 04-02-2003, 05:44 PM   #6
Rep Power: 28 rsaeini is off the scale
in his sig it says he's got an S.
Wouldn't the early H22 work well for turbo given they have a closed deck and all?
i say go for the H22.
"let those who judge me burn in hell until their Hondas are repossessed" - ME 1.6-1.8
rsaeini is offline   Reply With Quote
Old 04-02-2003, 05:49 PM   #7
WRX Sellout
Well, it says in his sig that he's got a "Type S". Which I doubt, or else he wouldn't be talking about doing a swap.
Anyway, the 92-96 Ludes do indeed have closed decks, which are good for boost, but you can't use the stock sleeves if you're planning on running forged pistons. So it has to be resleeved anyway if you want to run anything greater than 6-8 psi.
The H22 is just fine to boost, but requires extra (precise) tuning due to the fact that VTEC and turbo don't get along nicely when not tuned together.
Old 04-02-2003, 05:53 PM   #8
ok, inlight of new info i change my verdict...go for the H23. :P
Old 04-02-2003, 06:30 PM   #9
Rep Power: 15 luVTEC is off the scale
I agree you've already got a good motor. Dont go for higher compression if you want to boost , for high HP I'd say go turbo for shure, if you want to really boost it build the internals, lower compression forged pistons/rods perhaps as part of a stroker kit.
If you want n/a high HP (why?) , then get higher compression pistons, better cams etc.
underpowered 93 Civic DX
luVTEC is offline   Reply With Quote
Old 04-03-2003, 08:17 AM   #10
The motor i have in my car right now is a 2.2L im thinking. Its the stock motor the only thing i have upgraded is a cold air intake. If i have to money to spend would it not be a bad idea to do a H22 motor swap? Or should i just take the motor i have now out of my car and only do a top half h22 motor swap like change over to the h22 heads and use the DOHC ? And change the pistons , rods , rings , cams , and put some headers on it? I appreciate the help like i said im just now kinda catchin on to all this.. Thanks....
- K&N Filter
Old 04-03-2003, 09:14 AM   #11
WRX Sellout
He really doesn't already have a good motor. Read my post. The Prelude S has the same engine that comes out of a 90-93 Accord. A DOHC head won't fit on it, and it's a crappy platform for ANYTHING....high compression n/a OR boost.
Old 04-03-2003, 10:33 PM   #12
Ride:  2006 Audi A4
Rep Power: 116 totalburnout has a brilliant future
totalburnout has a brilliant futuretotalburnout has a brilliant future
Send a message via AIM to totalburnout
...I wouldn't really be considered about HP unless you're trying to impress people.
Torque is whats going to give you speed off the line.
the h22/3 is a good "torque-y" engine for a honda and would be a good place to start from, plus it would be real sweet if you boosted it.
"Good talk... I'll see you out there."
totalburnout is offline   Reply With Quote
Old 04-03-2003, 10:47 PM   #13
he's already got a 2.2L, boost it and you'll get lots of TQ, that will fire you down the 1320
Old 04-03-2003, 10:50 PM   #14
Ride:  2006 Audi A4
if what everyone is saying is true its a shit platform so why drop money into it ?
if you start off weak its always going to be weak
Old 04-04-2003, 09:04 AM   #15
WRX Sellout
A 2.2-liter pile of poop is still a pile of poop, just a bigger one.
A boosted pile of poop is still a pile of poop, just one that will be prone to blowing up quicker.
You can't "just boost" that engine. It's weak, it's got a weak tranny, and it's SOHC, which doesn't allow for as much tuning. If he REALLY wants to, he can build it for boost. But for the money he'll throw into making that SOHC 135-hp-wonder boost-capable, he could have an H-series engine that's alot stronger from the factory, not to mention the extra cam.
Old 04-04-2003, 10:46 AM   #16
Rep Power: 14 white_hot_wagon is off the scale
Send a message via MSN to white_hot_wagon
i'm gonna go with everyone else and say that his motor is a P.O.S. i had a boosted h22 in my wagon (yes a '91 accord wagon) that ran 12.30's on drag radials. i sold that motor to make some cash and put the old f22 back in. the h22 just like the f22 (or any motor) requires building to handle more than 7-8 psi. but once you build the h22 it will be more reliable because of the closed deck and the cam tuning ability doesn't hurt either. in the long run if he tries to boost his current motor he's gonna run into a lot more problems than with a built h22. but i think turbo is the way to go hands down for high hp
sold my wagon
i'm hondaless once again.
looking for a 5th gen hatch
eating crap in an '89 probe gt 16.03@87mph
white_hot_wagon is offline   Reply With Quote
Old 04-04-2003, 10:49 AM   #17
WRX Sellout
Well-said.
Old 04-04-2003, 01:11 PM   #18
Rep Power: 15 whatdahieu is off the scale
turbo h22 accord! me likeee
whatdahieu is offline   Reply With Quote
Old 04-04-2003, 01:11 PM   #19
WRX Sellout
Yeah I need one of those.
Old 04-04-2003, 01:25 PM   #20
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Wise man say: Big boosted piles of poop make stinky fly in face faster and harder than non-boosted piles of poop.
Old 04-04-2003, 01:30 PM   #21
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
There you go again, back into the sig.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 04-04-2003, 01:34 PM   #22
WRX Sellout
Haaaaaaaaaaaaahahahaha
Good thing the boss is gone, that's f-in hilarious.
Old 04-04-2003, 01:39 PM   #23
Rep Power: 15 Holy_racer is off the scale
Hey, I believe you have a 1994 prelude si, right? If your prelude is a si then it's a h23. Also, i believe that all prelude from 92-95 are all 2.3 and 2.2vtec. Since you already have a h23 you could just add a turbo and do some internal upgrade then you'll be running pretty good on the track. Don't bother to get a h22a jdm swap because it's just gotta cost you the same price as you're adding a turbo to your car. Beside, if you do a h22a jdm swap you'll be running around 15sec stock, but if you add a turbo to your h23 i think you'll get a better time.
Holy_racer is offline   Reply With Quote
Old 04-04-2003, 01:53 PM   #24
Rep Power: 15 Distorted is off the scale
Send a message via AIM to Distorted Send a message via MSN to Distorted
Originally posted by dohcvtec_accord@Apr 4 2003, 09:09 AM
You can't "just boost that engine. It's weak, it's got a weak tranny, and it's SOHC, which doesn't allow for as much tuning. If he REALLY wants to, he can build it for boost. But for the money he'll throw into making that SOHC 135-hp-wonder boost-capable, he could have an H-series engine that's alot stronger from the factory, not to mention the extra cam.
Oh heavens! Its only a Single Cam! My SOHC will Cam slap most DOHC's out there. Think about the COSTS involved for the GAINS. Is buying another motor, just to get another cam really worth it? You have a motor, so your basically duplicating. I'm not sure about the SOHC H series motors, but if i remember from a friends engine, the H22 turbo actually needs custom pistons to be useful in a turbo application. The rings sit up to high on the piston and are quickly destroyed, i would also recomend resleeving it if you do go with a DOHC or SOHC, i forget up i think some H22 turbos had problems on stock sleeves, but that can be true of any engine and maybe just a coincidence. But either way, with all the money he could spend on buying a DOHC H22, building it, and boosting it, he could have one kick ass SOHC. Either way the engine will be "alot stronger fom the factory", duh, he's building it. But then again, 2 cams..that means like...an instant 20hp before the turbo right? Now, like you asked, the BEST platform would probably be the DOHC engine H22...not because its DOHC nessecarily, but because there is a great wealth of knowledge and experience in its building, on this board and probably in your area. \
Rob
SOHC turbo. Does the body good.
Distorted is offline   Reply With Quote
Old 04-04-2003, 01:55 PM   #25
hey prelude guy, is your prelude a single cam? if yes, i think you got ripped off because all prelude from 92-95 are suppose to come with h23 or h22.
Assembling an LS/VTEC pissedoffsol General Tech Articles 1 06-04-2004 11:17 AM
Engine Removal Guide pissedoffsol Swap Articles 0 01-12-2004 02:19 AM
Jdm Engine Swap icedog75 General Tech and Maintenance 2 06-16-2003 01:52 PM
Benefit of using Higher Octane? pissedoffsol General Tech Articles 0 09-28-2002 01:37 PM
85-87 ECU Error Codes pissedoffsol Reference Materials 0 09-28-2002 01:29 PM
