This is about the only thing I have NO idea about with my swap.
I have the vtec solenoid, vtec oil pressure, and knock sensor all wired at the shock tower engine harness all neat and $hit! I looked through the electrical part in my GSR helms manual and I can not find find the pin ID's for the shock tower harnesses for the IAB. The IAB plug is shown in the pic but it's going to be pretty hard to tap in under the manifold. Where do you guys tap in for this wire to run back to the ECU (A17) ![]() When I unwrapped my Cx wire harnesses wires are spliced underneath the loom / electrical tape. At some points different color wires would spice in and come out to one wire a totally different color :hammer: Has anyone ever traced the IAB wires back to the shock tower harnesses? If not, where is the best place to tap in to this and run it back to the ECU? There are 2 wires on the IAB above. A reb / blue wire and a black wire that is hard to see. Does it matter which one you tap into? Is the black a ground? Thanks! __________________
<span style=\'color:red\'>FT: My *clean* EK Hatch for Your *clean* EG Hatch!! Hit me up!</span> |
#3 | |
Thanks for the info! __________________
yeah, that is right,...pull the plug off the solenoid... cut the red/blue.... add about 5 feet of wire to it, and flex-loom it. run it along the firewall and run it thru the grommet i mentioned earlier.. then you can pin it into A17
| How to wire vtec | 92b16vx | General Tech Articles | 3 | 06-17-2005 06:13 PM |
| questions | rushcrx | HYBRID -> ED-EF / DA | 6 | 06-29-2004 11:54 PM |
| 92 civic cx with ls motor 4 wire o2 help | lsvtechater | HYBRID -> EG-EK / DC | 2 | 11-04-2003 11:13 PM |
| good sites for stereo installs | WetWilly | Car Audio / Security / Electronic Accessories | 4 | 08-26-2003 12:28 PM |
| How To Make Physical Wire Connections | dkasakitis | ECU's, Electronics, and Tuning | 3 | 01-27-2003 02:01 AM |
