Where is MAP sensor
Old 07-17-2004, 09:42 PM   #1
Rep Power: 0 ronhonda is off the scale
Just finished swap and getting 3 codes (map). WHere is MAP on JDM B16 A2?
Autrozone sells for $140 !.... , but didn't have it. What does it look like?
Thanks
ronhonda is offline   Reply With Quote
Old 07-17-2004, 10:00 PM   #2
Rep Power: 13 bklyneg is off the scale
top of the throttle body
bklyneg is offline   Reply With Quote
Old 07-17-2004, 10:01 PM   #3
Not on mine!
Old 07-18-2004, 04:17 AM   #4
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
If it isn't mounted on top of the TB, than it is attached to the TB via a hose, and mounted on the firewall.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 07-18-2004, 07:15 AM   #5
Old 07-18-2004, 07:17 AM   #6
The old engine had the MAP mounted above the TB air intake, but the new B16 A2 has no MAP that is that I can find. Will I have to add one? All the connectors plugged in and I have no loose wires!
Thanks
Old 07-18-2004, 10:55 AM   #7
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
In the picture below you can follow the hose off my TB to the firewall, that's where my MAP is.
95 CX|B16A2
Old 07-18-2004, 10:14 PM   #8
Post
92b16xx,
My civic engine had the MAP mounted on the TB above the intake opening. The wiring was incorporated in the CIvic engine harness (Yellow/red, Green/white, and White).
The B16 engine harness had no MAP wires (and empty spade clips in the connector), so you are correct that the ECU must have been mounted on the firewall of the engine donor vehicle. I'll call Hmotors Monday and get the to send me a firewall mounted MAP.
Thanks for the help.....
Ronnie
PS, the engine runs, but pretty weak. Revs good and will crank 7K but has little power. Think the MAP will help?
THANKS Guys
Took MAP sensor off TB and hooked to B16 via a hose. The engine harness had no MAP wiring, so spliced into Civic wiring harness.
Really Hums now. B) B) ....VTEC and all.
Throwing 23's when VTEC kicks in.
Any ideas
