will an obd1 engine harness function in an obd2a car?
Old 01-04-2006, 05:11 PM   #1
Rep Power: 14 Sinner is off the scale
I have a 97 integra and I want to swap in a obd1 engine that comes with a obd1 harness. I no longer have an obd2 engine harness. So my plan is using 97 integra w/ obd1 engine and harness engine harness controlled by obd1 ecu which is connected to an obd2->obd1 ecu harness.
Thanks,
Nick
Sinner is offline   Reply With Quote
Old 01-04-2006, 05:54 PM   #2
Rep Power: 25 SixtySecondAssassin is off the scale
yep, that'll work. i dont know if this is required where you live, but here, on obdII vehicles, the diagnostic port is checked at inspection time. you might want to look into that.
.....deagle.....
SixtySecondAssassin is offline   Reply With Quote
Old 01-04-2006, 06:32 PM   #3
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
<div class='quotetop'>QUOTE(SixtySecondA ssassin @ Jan 4 2006, 11:54 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Isn't the port in the cabin though...if so, shouldn't make a difference if you just use the OBD I engine harness. For the tegs the harness are pretty much the same.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 01-05-2006, 11:24 AM   #4
yea, everything will plug in and run fine. but when the diag. port is hooked up to the odbII computer checker thing at inspection time, the odbI ecu wont communicate with it. he should check as this could become a hassle for him at inspection time.
.....deagle.....
Old 01-05-2006, 11:36 AM   #5
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
in relation to this subject will an obd1 engine harness plug into an obd2b civic/teg?
just thought i would ask....
*not trying to thread jack*
just more info for other readers... [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img] [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
http://pandora.com/
Old 01-05-2006, 12:01 PM   #6
it will only work for obdII intergras. the obdII civic's harness doesnt split at the firewall on the passenger side like earlier civics and integras.
.....deagle.....
Old 01-05-2006, 03:19 PM   #7
Rep Power: 15 drpenguin is off the scale
Send a message via AIM to drpenguin Send a message via Yahoo to drpenguin
im using a obd2 engine harness on my b16 in my EG. everything plugs in and runs. minus the injectors i had to put obd1 clips on it but its all the same for everything else. i think you can even plug the obd1-2 stuff into the harness. the alt, dizzy and all your sensors should be the same plugs and everything.
93 Si HB, B16A swap OBD1, GSR hydro tranny, 6 puck clutch,`1 Nitrous Express NXL 60shot ,Front and Back Strut bars, 99 Si rims, 2.25 Exh w/ flowmaster axle back, Ebay Short Shifter, Ebay intake, Megan Type R replica 4-1 headers
dynoed on old tranny and stock clutch was 137 WHP and 177 w/ nitrous
Our rides are dubbed rice burners because we aren’t housing some outdated, pushrod,gas guzzling, carbureted, iron-block V-8 engine under our hoods. What out industry has takes a lot more technique. Forcing 250 HP out of a tiny 1.6L engine.... Now look where the so-called rice burners are. Four-bangers are spinning more then 1,000 hp on the dyno and knocking down Pro stock-like times down the quarter-mile.
drpenguin is offline   Reply With Quote
