Facebook Twitter
wireing for H22 in 92 DX
This is a discussion on wireing for H22 in 92 DX in the HYBRID -> EG-EK / DC forum
about to install a JDM H22 in my 92 hatch DX, i undertand that the 92's came with all but one VTECH wire? as far as installing the JDM H22, how hard is the wireing going to be and does any place make an easy ...
Old 08-21-2003, 01:31 AM   #1
about to install a JDM H22 in my 92 hatch DX, i undertand that the 92's came with all but one VTECH wire? as far as installing the JDM H22, how hard is the wireing going to be and does any place make an easy harness to just plug in besied HASPORT?anything i should look for or do before the install?
12scrx is offline   Reply With Quote
Old 08-22-2003, 04:03 AM   #2
pissedoffsol's Avatar
there is no H in VTEC.
what year is your motor?
What ECU are you using? if you get an obd1 p13, you don't need a harness.
as for wiring, its the same as the p72- http://www.hondaswap.com/swap/viewer.php?id=57 but thats for obd1... which your car is, but if you are going to use an obd2 ecu (i don't know why you would but who knows) then you need to convert those pinouts with this chart: http://www.hondaswap.com/swap/viewer.php?id=58
Old 08-22-2003, 08:24 AM   #3
sorry about the H, it was late and i was tired, and yeh im defiently gonna use the obd1 (p13) ecu. i thought that there was an extra wire that had to be added, so is it almost a plug and play deal? well maybe not that straight forward. but is it?
Old 08-22-2003, 08:40 PM   #4
Man, i dont mean to be rude but wat ur contemplating is totally whack, i kno its been done and still will be done but if ur asking us how to do it, u shouldnt even consider doing it. The swap ur talking about is fawking hard, time consuming and cost mad bank if ur not doing the swap ur self. For the price of the total swap, u'll end up paying just as much as a b18c1 swap plus some.
dang civic is offline   Reply With Quote
Old 08-22-2003, 09:43 PM   #5
so even with the HASPORT mount kit and wireing harnes, still is madd hard to do? the only part i dont got figured out is setting up the linkage to the shifter, any idea anyone?
Old 08-22-2003, 10:47 PM   #6
sounds like everyone is a bit annoyed so..........
http://www.h22hybrid.20m.com/index.html
should have all the info you need
tripple sik is offline   Reply With Quote
Wireing B18a In 89 Crx Si crxsi ECU's, Electronics, and Tuning 8 12-09-2010 10:52 AM
difference in wireing ^crx^ HYBRID -> ED-EF / DA 4 07-11-2004 06:47 AM
H22A wireing 12scrx HYBRID -> EG-EK / DC 3 01-20-2004 08:31 AM
wireing b18c1 highperboi HYBRID -> EG-EK / DC 1 09-03-2003 02:45 AM
Crx Si To B18a Wireing crxsi ECU's, Electronics, and Tuning 1 01-21-2003 07:08 PM
© 2001-2013 HondaSwap.com
