wiring harness??
Old 11-02-2009, 10:51 PM   #1
Rep Power: 1 Rjs4490 is on a distinguished road
Question wiring harness??
what is the best wiring harness for my buddy to use on his b20b swapped civic? its the 97 ek. its being converted to obd1 by the jumper harness. the only wiring harness he has is the stock single cam 1. what would the best harness be for him to get?
Rjs4490 is offline   Reply With Quote
Old 11-02-2009, 10:53 PM   #2
Ride:  1991 civic wagon
Rep Power: 6 dc231581 is on a distinguished road
d16y8 is the easy choice
dc231581 is offline   Reply With Quote
Old 11-03-2009, 01:51 AM   #3
thats the stock harness he has right? im sure h knows but im just wonderin
Old 11-03-2009, 01:52 AM   #4
how much modifying will he have to do?
Old 11-03-2009, 06:15 PM   #5
99sidude's Avatar
Ride:  gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
Rep Power: 50 99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of
Send a message via AIM to 99sidude
You might have to just lengthen a few sections of harness if the plugs can't reach. This is easy to do if you have a soldering iron and heat shrink tube.
Originally Posted by Celerity View Post
The worst thing that car ever had installed was your lying two-bit fat ass in the left seat.
My Build: http://hondaswap.com/auto-multi-medi...sc-buld-94841/
93' dx hatch
jdm b18c - jrsc 8psi
s300 440cc RC's
99sidude is offline   Reply With Quote
Old 11-03-2009, 07:20 PM   #6
Rep Power: 0 intenseneal can only hope to improve
Yeah use the stock harness and lengthen where needed. You will also need to change a few things on the harness. Go to ff-squad.com for all the info and diagrams for the wiring. You need to chang the crank sensor plug and the AIC plug and move a few pins on the ECU plugs. I just did a Ls swap in my 98 Hx and the swap is almost excatly like swapping into an Ex. I used a Lx harness on my swap but I had a 5 wire O2 sensor. The wiring is super easy so dont worry.
intenseneal is offline   Reply With Quote
obd2 wiring harness or eg ex civic harness cooper ECU's, Electronics, and Tuning 9 09-01-2008 11:11 AM
Wiring Problem P06/Si Wiring Harness Inyourface1650 ECU's, Electronics, and Tuning 4 01-24-2007 03:07 AM
wiring harness rex187 HYBRID -> ED-EF / DA 8 04-15-2005 03:45 PM
WTB y8 wiring harness jesswa02ep Parts: For Sale/Trade/Wanted 0 03-08-2005 10:40 AM
need help with wiring harness? ripperbone ECU's, Electronics, and Tuning 1 02-18-2005 02:17 AM
