Wiring Question on B16A2
Old 09-29-2003, 12:50 AM   #1
Rep Power: 13 spooncivic01 is off the scale
Ok everyone that has done a obd-1 b16a swap on their civics please help.
I am wiring up my civic which is 93 CX and I am using a dhipped P28 ecu with the skunk2 program. So I know I don't need the knock sensor, but my question is for the rest of the wiring. For example I would take the wire from the vtec solinoid and run it to where the engine side of the harness before the firewall or do I run it all the way to the inside of the car and go into the ECU. If I could get so help that would be great.
Thanks
spooncivic01 is offline   Reply With Quote
Old 09-29-2003, 01:55 AM   #2
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
Only the 92's and some of the VERY first 93's were all wired for vtec in the cabin harness. So you are going to have to run it all the way. You can make it look clean as stock, by getting some pins for the plugs, and running the wire into the loom, soldering it to the pins to the wires, and plugging them into the plugs, and then running it to the ECU. Basically just doing what they should have in the first place.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 09-29-2003, 01:56 AM   #3
Thanks That is very helpful. Time to go outside for a long night in the garage.
distributor and wiring harness question mrnice1058 HYBRID -> EG-EK / DC 5 10-30-2009 12:57 PM
wiring harness question mrnice1058 HYBRID -> EG-EK / DC 4 07-02-2004 08:20 AM
DX to SI wiring question (call me a moron) Civic_Tacoma ECU's, Electronics, and Tuning 4 06-08-2004 06:32 AM
Civic D16 > B16A2 Swap Question SIdun HYBRID -> EG-EK / DC 0 01-04-2004 01:51 PM
92 Cx Wiring Question dansace HYBRID -> EG-EK / DC 19 01-13-2003 01:35 AM
