won't rev beyond 3500 rpm
Old 10-01-2005, 07:35 PM   #1
triniDEMON is off the scale
ok guys and honda techs...............i just did the swap
i have a d16z6 head with a d16y8 head and i am currently using a dizzy from a d15b7 motor
(my car is a 1993 honda civic ex it came with a d15b7 (canada)
i am getting a code 4 code 20 and i think code 36
i dont know wtf code 36 is???
i am using a p28 ecu
i get the effect and codes even when i use my p08 ecu
i think its the dizzy causing the problems
any advice please reply thank you [img]style_emoticons/<#EMO_DIR#>/blink.gif[/img] [img]style_emoticons/<#EMO_DIR#>/blink.gif[/img] [img]style_emoticons/<#EMO_DIR#>/blink.gif[/img]
triniDEMON is offline   Reply With Quote
Old 10-02-2005, 03:10 AM   #2
VTECin5th's Avatar
VTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of light
Send a message via AIM to VTECin5th
4- Accord Civic CRV CRX Del Sol Odyssey Prelude
90-98 88-98 97-98 88-91 93-97 95-98 85-98
CKP Sensor (Crankshaft Position Sensor)
defective circuit or unplugged / defective sensor
20- Accord Civic CRV CRX Del Sol Odyssey Prelude
90-98 88-98 97-98 88-91 93-97 95-98 92-98
Electrical Load Detector
I'd fix those first before trying to troubleshoot the dizzy?
Are you sure it's 36 and not 45?
VTECin5th is offline   Reply With Quote
Old 10-02-2005, 11:57 AM   #3
Unhappy
ok i am goin 2 check over the timing belt and the tiiming setting
my car worked fine today 4 a while until it started 2 bogg out when i crossed 4000 rom
dizzy looks good
thank u
Old 10-02-2005, 04:06 PM   #4
ok where the f%^k is the crank shaft sensor located????
the timing is dead on
Old 10-02-2005, 09:45 PM   #5
VTECin5th's Avatar
<div class='quotetop'>QUOTE(triniDEMON @ Oct 2 2005, 04:06 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
no idea [img]style_emoticons/<#EMO_DIR#>/huh.gif[/img]
Old 10-03-2005, 06:10 PM   #6
jlicrx's Avatar
jlicrx has a brilliant future
<div class='quotetop'>QUOTE(triniDEMON @ Oct 2 2005, 03:06 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
in the distributor - non serviceable item - replace distributor
Old 10-03-2005, 10:55 PM   #7
ok my timing is dead ON
i am goin 2 try and switch dizzy
ohhh my wire harness has 2 plugs that go into the dizzy one plug has like 6 wires the other plug has
2 wires (black and blue)
the dizzy that came with the motor(d16y8 head)has only 1 plug
any ideas (i am using the dizzy off my old motor d15b7)
how can i check the signal for the crank position sensor....what color wire is it????
mayb i have a bad wire....lol
thank guys
Old 10-04-2005, 09:33 PM   #8
Cool
[ok guys
i switched the dizzy today and replaced it with another dizzy from a d15b7(AND YES IT FITS ON A D16Y8 HEAD)
AND EVERYTHING WORKS FINE
the motor doesnt pull strong as it should so i am goin 2 triple check the timing and reset it!!!!!!!
i will let you know hoe it works out
