worth 3000?? yes or no
Old 10-20-2009, 03:34 PM   #26
SlushboxTeggy's Avatar
Ride:  1997 Integra
Rep Power: 196 SlushboxTeggy has a reputation beyond repute
SlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond repute
Send a message via AIM to SlushboxTeggy Send a message via MSN to SlushboxTeggy
Originally Posted by Rjs4490 View Post
skunk 2 cams....cam gears...cam seals...fuel rail...intake mani and throttle body....headers...coil-overs..retainers..springs...forged valves...all by skunk2 brand
There is only one cam seal and only one header.
A S2 cam seal will do nothing for you. It's a seal. Unless the stock one is leaking, there is no reason to replace it.
S2 cam gears will do nothing unless you have plans on advancing or retarding the timing.
A S2 fuel rail isn't necessary. The stock one will handle your needs, especially while you're NA.
And I hope you know coil-overs aren't an engine part.
Sounds like you should read up on how to go about building an engine before you just bling out your engine compartment with unnecessary spending.
Like water on a duck's back, just let it roll off...
RIP Shaunie T. O'Reilly- 1986-2006
SlushboxTeggy is offline   Reply With Quote
Old 10-20-2009, 04:17 PM   #27
I'm just EF'n..
!JDM_EF-9!'s Avatar
Ride:  91' civic Dx
Rep Power: 18 !JDM_EF-9! is a glorious beacon of light!JDM_EF-9! is a glorious beacon of light!JDM_EF-9! is a glorious beacon of light!JDM_EF-9! is a glorious beacon of light
myspace
93 honda civic vx hatch.
built lsvtec
95 b18b1 block
oem honda pr3 b16 pistons 11:5.1 comp.
oem honda piston rings
arp rod bolts
oem honda crank and rod bearings
type r oil pump
gsr water pump
gsr timing belt
oem honda headgasket.
hondata intake mani gasket
p30 b16 intake manifold
dc sports race header with 2.5 inch collector
2.5 inch exhaust with 2.5" vibrant muffler
golden eagle lsvtec kit
99 b16 head
supertech valve springs and retainers
gsr cams
gsr trans with act clutch
chipped p28 ecu
with cams and a tune car will easily go low 13's. as of right now best time is 13.9 on bf drag radials.
its captiva blue with a new front end. so the front is black. has a dent and small rust on driver side quarter panel. other than that its clean. rides smooth. stock suspension in the back with coilovers up front. real jdm headlights with jdm corners. ek yellow fog lights. cf duckbill.
gsr rear cloth seats and integra ls cloth front seats. clean black interior. 226k on the shell. clean title. comes with steelies and hub caps with brand new tires.
The kid i bought the car from ran it at the track and he ran 13.9...i have the slip...he wiegh's 300 pounds...i wiegh 150 lol...im going to skunk 2 the shit out of the car and run low to high 12's..then turbo =)...who knows what ill run lol
you already got the motor so I say start wit suspension first before you "skunk 2" anything!
DONT FORGET TO REP A BROTHER.
XBL Gamertag: SIROSKERCHIEFS
(COD4,HALO 3,COD: WaW,soon to come COD4:MW2)
91 CIVIC HB DX:Stock B16a swap,lowered,sittin on slipstreams.
!JDM_EF-9! is offline   Reply With Quote
Old 10-20-2009, 05:17 PM   #28
I'll be back...
B16RacerN2NR's Avatar
Ride:  06 Mazda 5, 91 Civic DX
Rep Power: 156 B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
skunk 2 cams....cam gears...cam seals...fuel rail...intake mani and throttle body....headers...coilovers..retain ers..springs...forged valves...all by skunk2 brand
How did you come to the conclusion that these parts will put you anywhere near 12's? I really want to know. Not because i'm trying to talk shit but because i really wanna know how these theories come about so we don't have a ton of misinformed people out there...
Real Eyes Realize Real Lies
B16RacerN2NR is online now   Reply With Quote
Old 10-20-2009, 07:59 PM   #29
Dark93DX's Avatar
Rep Power: 10 Dark93DX is on a distinguished road
^^^^ was wondering the same thing.
It ran 13.9 as is and some how throwing a few Skunk2 parts at it will get you into low 12's?
K20Z3 EG - Installed, waiting for Kpro
LSD w/ 4.764 FD
B18A CRX
Dark93DX is offline   Reply With Quote
Old 10-20-2009, 11:24 PM   #30
Rep Power: 1 Rjs4490 is on a distinguished road
well i guess im an idiot lol...maybe i wont "skunk 2" anything but coilovers ...but showing what i have already done...what should be my next step????
Rjs4490 is offline   Reply With Quote
Old 10-20-2009, 11:36 PM   #31
Dismember
Ride:  Whatever i can get behind the wheel of
Rep Power: 263 klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
Set a realistic goal and work toward achieving it within a budget.
klyph is offline   Reply With Quote
Old 10-21-2009, 12:00 AM   #32
but what should i do to the car next??
Old 10-21-2009, 11:40 AM   #33
wwtdd?
95b16coupe's Avatar
Rep Power: 215 95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute
95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute
upgrade the suspension, brakes, and tires.
as it sits now, you probably don't drive good enough to push that car to the limits. practice driving techniques before you start screaming MOAR POWAH!!!!
Warning: If you are reading this then this warning is for you. Every word you read of this useless fine print is another second off your life. Don't you have other things to do? Is your life so empty that you honestly can't think of a better way to spend these moments? Get out of your apartment. Meet a member of the opposite sex. Stop the excessive shopping and masturbation. Quit your job. Start a fight. Prove you're alive. If you don't claim your humanity you will become a statistic.
95b16coupe is offline   Reply With Quote
Old 10-21-2009, 11:58 AM   #34
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
Suspension, and brakes. Driving a car with a powerful engine that handles like a wet sponge sucks. I wouldn't put a dime into the motor until the car can handle more power, and stop well.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 10-25-2009, 08:55 PM   #35
Greenhorn
Ride:  92 Dx 4 door 5 Speed
Rep Power: 0 xeroxero is on a distinguished road
myspace  FaceBook
I trust pictures far from speculation. pics and receipts are always good.
xeroxero is offline   Reply With Quote
Old 10-26-2009, 09:18 PM   #36
Rep Power: 6 bluejcivic is on a distinguished road
the motor and tranny are almost worth 3 grand. your pretty much getting a free car =)
bluejcivic is offline   Reply With Quote
Old 10-26-2009, 09:26 PM   #37
99sidude's Avatar
Ride:  gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
Rep Power: 50 99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of
Send a message via AIM to 99sidude
assuming the car hasnt been flogged to shit
Originally Posted by Celerity View Post
The worst thing that car ever had installed was your lying two-bit fat ass in the left seat.
My Build: http://hondaswap.com/auto-multi-medi...sc-buld-94841/
93' dx hatch
jdm b18c - jrsc 8psi
s300 440cc RC's
99sidude is offline   Reply With Quote
Old 10-28-2009, 01:39 AM   #38
lol very true
Old 10-29-2009, 09:15 PM   #39
Ride:  1991 civic dx
Rep Power: 9 efalex has a spectacular aura aboutefalex has a spectacular aura aboutefalex has a spectacular aura about
myspace
was the motor built from a legit place? and why is there a black front?! got hit?!
efalex is offline   Reply With Quote
WTB: $3000 civic vteclude22 Vehicles: For Sale/Trade/Wanted 1 02-05-2008 09:55 PM
Need Help - engine cut of gas at 3000 rpm. fanete Civic and del Sol - EG and EK 29 01-10-2007 09:52 AM
$3000 to spend DerekW Engine Building 9 10-20-2006 06:49 PM
i have 3000!!! i want to buy a car now. r.l.brown Vehicles: For Sale/Trade/Wanted 8 03-18-2004 04:29 PM
Would You Pay $3000 For This Engine? civ90hb Engine Building 14 05-26-2003 10:59 AM
