Facebook Twitter
Y7 into 99 civic ex
This is a discussion on Y7 into 99 civic ex in the HYBRID -> EG-EK / DC forum
i have a 99 civic ex with the sohc d16y8 vtec replaced by the non vtec d16y7 from a 98 civic dx still using the y8 tranny, harness, and p2p ecu it is now throwing engine check light for vtec what would i have to ...
Old 04-10-2012, 07:17 PM   #1
Default Y7 into 99 civic ex
what would i have to do to run this setup, clear ecl and pass smog?
89guts is offline   Reply With Quote
Old 04-16-2012, 10:31 PM   #2
tabKola's Avatar
You would have to get a 99-00 P2E ecu and then move/add some wires for the IACV if your car is a 5-speed or you could swap on the head from a D16y8.
tabKola is offline   Reply With Quote
Old 04-17-2012, 09:52 PM   #3
what would i need to do if i chose to replace the head and put back a y8 again
im guessing the timing and dizzy right? what else needs to be done?
Old 04-18-2012, 01:03 AM   #4
tabKola's Avatar
You literally just remove the Y7 head and intake manifold and swap over the Y8 head and intake manifold. Dizzys/timing is the same between the two. You will have to swap over the knock sensor from the Y8 as well.
© 2001-2013 HondaSwap.com
