i have a 92 cx hb with a d15b7 and plan on doing a mini-me head swap.
I am wondering if there are any advantages or disadvantage in using one head or the other. I read somewhere about having to modify the distributor, which head is this? any help is appreciated... thanks in advance |
#2 | |
Member of the 20 nut club
just use a Z6 head .... its OBD-1... less problems with wiring shit
МОΛΏΝ ΛΑΒΈ |
i have the y8 head, to do the mini-me on my d15b7. u have to modify the distributor with the z6 head, and the y8 gives a lil more power. i.e. higher compression, also it probably is in better condition as it is newer....my 2 cents
[/quote]Silverchild79 on Jun 6 2004, 10:59 PM And god forbid you should have to defend the country you benifit from...... |
#5 |
i used z6 head & gasket
<div class=\'quotetop\'>QUOTE</div><div class=\'quotemain\'><span style=\'color:blue\'>*BAR/HONDA enigeer: Turbo Division*</span></div> <div class=\'quotetop\'>QUOTE</div><div class=\'quotemain\'><span style=\'color:blue\'>New Civic need to swap everything </span></div>b16a2 w/ Darton Sleeves/Probe Pistons/Eagle Rods turbonetics 60-1 Aem ems Aem Uego Full-Race Tial 44mm Wastegate Tial 50mm BOV .. .. Still builing up |
#6 |
if i were you i would use the z6 head with the y8 manifold i just replaced my z6 manifold for the y8 and i noticed a huge differnence right when vtec hits, the y8 might have more hp but in the long run the z6 outflows the y8
Man....people are kinda odd so I keep my eyebrow raised, I only hear words for what they mean, Know what I mean? And I do believe in God, cuz i keep coming across all these fine women with low self-esteem, You know what I mean. |
#7 |
Z6 head may be alittle easier considering it is already obd1, and there may be less problems. However, a y8 head i beleive will have larger intake rails on the manifold and a little better valve train. I have a z6 right now and it sucks. It is in my opinion the shittiest motor ever produced by honda. My hf ran better than this piece. if you are going to do any swapping, go b-series.
Boosted LS CRX --- Loving the fact that it never runs. After 10G's of work without drivability - seriously considering setting it on fire. |
#8 |
So, i would have to modify the distributor if I use the Z6 head??
I thought that it would be the other way around, that is... I would have to modify the Y8 head since it is a 6g the Z6 head is a 5G. ?????????????????????????????????? |
#9 |
OOPS.....I have a D15B8!!!!
I thnik the only difference is the B8 has 8 valves and the B7 has 16 valves. Correct me if I am wrong... thanks |
| d16z6 to d16a1 head swap?? | Tenzodelsol | Engine Building | 4 | 04-09-2004 02:06 PM |
| B16 head swap | camelian | HYBRID -> EG-EK / DC | 1 | 10-04-2003 03:50 PM |
| tell me if f22b1 head can swap to f22a1 block | accord tuner | HYBRID -> BA-BB /CA-CD | 3 | 01-14-2003 01:04 AM |
