Facebook Twitter
Zc Sohc Vs Zc Dohc
This is a discussion on Zc Sohc Vs Zc Dohc in the HYBRID -> EG-EK / DC forum
Ok I have the stock motor that come out my CRX 91 SI. Ok I want to know, to make sure. I can put a ZC head on the si block right???? Ok and I don't know if I want to go with the SOHC ...
Old 04-02-2003, 03:46 PM   #1
Arrow
Ok I have the stock motor that come out my CRX 91 SI. Ok I want to know, to make sure. I can put a ZC head on the si block right???? Ok and I don't know if I want to go with the SOHC or the DOHC. Right now I have a DOHC in my CRX. But I think I want to try the SOHC out. Cuz I got a pal that has one in a 91 HB and he likes it. So tell me what you think??? Thx
delsolty is offline   Reply With Quote
Old 04-04-2003, 11:02 AM   #2
go with a DOHC ZC motor and then put a junkyard turbo setup on it thats pretty easy to do and very cheap im getting a ZC motor today or tomorrow for only about 100 bucks! well lemme know how things work out for ya.... later
b18vtecrx is offline   Reply With Quote
Old 04-04-2003, 11:58 AM   #3
Calesta's Avatar
You can't swap between SOHC and DOHC heads. If you already have a DOHC D block in there, you're not running the stock engine. If you want to try out a SOHC engine, you'll have to pull the whole engine, not just the head. SOHC ZC engines are pretty hard to come by, so you might just want to switch to a SOHC VTEC if you want to go SOHC D series. In any case, the DOHC ZC is the most powerful D series block (stock), so going to a SOHC powerplant will make your power levels drop a bit.
Intercrew Auto Salon
Old 07-24-2009, 07:25 PM   #4
Default dohc-sohc?
so you can switch the heads on a zc block to make it dohc or sohc?
HkDx is offline   Reply With Quote
Old 07-24-2009, 08:38 PM   #5
Dark93DX's Avatar
This thread is 6yrs old.
Dark93DX is offline   Reply With Quote
Old 07-24-2009, 11:14 PM   #6
'nuff said.
buttered corn is offline   Reply With Quote
DOHC or SOHC ??? elwalvador Engine Building 12 06-04-2004 05:54 AM
SOHC or DOHC hmanb16 Forced Induction 19 02-09-2004 12:59 PM
sohc or dohc 97 turbo coupe HYBRID -> EG-EK / DC 15 10-22-2003 01:46 PM
Dohc Vtec Or Sohc Vtec MXDesa HYBRID -> EG-EK / DC 6 05-27-2003 05:30 AM
Dohc Vtec Swapped Inplace Of Sohc dopeylude Engine Building 2 01-23-2003 01:13 AM
© 2001-2011 HondaSwap.com
a SkeyMedia network site | Advertise on Hondaswap.com
