Is there a way that i could swap a b16 into a 2002 Honda civic LX. Is there motor mounts for it. I think that swaping a B16 would be less expensive than a K20 but i do not know if a B series is even possible. If anyone knows please reply.
Thanks, Importman Please feel free to E-mail me @ importman1983@aol.com |
B happy
Ride: dohc 95 egg
Aren't they pretty much the same power output?It would cost more but the K20A2 from the rsx would be a lot easier and a actual upgrade.
you have a d17 in your car right now, correct?
now i realize not much information is known about the 7th gen's but i'm nearly positive a b-series motor will bolt in with b-series mounts. its doubtful honda changed the entire front-end geometry of their cars simply because the shell has a new look. i could be wrong though...i really don't have much experience with 7th gens. and an rsx motor can work, but its a lot of work, and very expensive and changes the entire geometry of the car, as its mounted backwords compared to conventional b/d series motors. __________________
<a href=\'http://www.geocities.com/coker_boy/honda.html\' target=\'_blank\'>The Green Machine</a> |
Admin with a big stick
Ride: 2003 S2000
![]() The B series is easier to drop in than the K... but it probably won't be very kosher, especially since there was no B block made in 2002. ![]() People have put B16s into 7G non-Si Civics already- it's not nearly as bad as putting a K20 in. __________________
#5 |
But then there is the whole legality issue of an older engine in a newer car...
depends on what you want to do w/ the car and where you are. __________________
a,b,c,d,ew,f,h,j,k,zc Honda fan w/ out a Honda. 00 GTI 1.8t "now before I finish, let me just say I did not come here to show out, did not come here to impress you because to tell you the truth when I leave here I'm GONE! & I dont care WHAT you think about me..." |
#6 |
same here. i wanna go with the b's. i dont know what my car is called in the us, but it has the ep3 front, but four doors. with a d17a2 engine. i have researched and finally, found this thread where calesta said that "it is easier to drop a b's than k's in 7g civic" that really relieves me coz other forums says im crazy. i live in indonesia, legality is not an issue here. so calesta, do i have to make custom mounting to fit the b in my car?
#7 |
Führer Mod
what state you live in?? in CA that is a big no no
nevermind.. reading owns me |
#8 | |
Ride: 2003 S2000
Yes, you would have to make custom mounts to put a B into a 7G Civic. I also made all those posts over 3 years ago when the 7G Civic was first being swapped. It's much easier to put a K into a Civic now- it's actually one of the most sought after swaps for a Civic these days. Most companies make conversion kits to mount the K. HASport's is excellent, and Innovative also makes a decent kit. The reason why I said the B would be easier back then is because the B and D spin the same direction, and the engine bay configuration would be relatively the same layout as before. That's not the case anymore. You're probably better off buying a mount kit and putting the K drivetrain into your Civic. __________________
#9 |
hahaha yes...i didnt notice the time it was posted though..sorry.
ok i know hasport does make mounts for the k's but it is too expensive for me. i wanna know, my car (eu3 / 4 door ep) uses a cable tranny. the gear stick position is on the dashboard (not the chassis) can i use any b-series cable tranny? i have a b16a engine right now, and planning to use the b20 cable tranny. i want to keep the gear stick on the dash. is this possible? |
#10 |
Ride: 2003 S2000
You'd have to find some way to make a custom shift linkage and mount I'm sure- I don't know how the dash is laid out on the dash shifters. The B series cable transmissions refer to how the clutch is activated, not the gears- the linkage is solid.
#11 |
hey man my name is cad and we have the same car my brother just got me started on tuners and i still know very litlle about it just picking up the basics i think he has a b16 or a b18 in his acura 92' but im not quite sure msg me back and maybe you could teach me some things about tuners
#12 | |
#13 | |
if there are minor modifications, what are they? right now, im planning to get a K instead of B. so im gonna need all the informations other than just the engine mounts... thank you all... |
#15 | |
anywyas id go for a k20a but they cost so damn much |
| TONS of parts for sale B16, GSR, Type R | Envy_Motorsports | Parts: For Sale/Trade/Wanted | 25 | 10-16-2008 01:08 AM |
| Digitally Imported Trance | Cashizslick | Members' Lounge | 12 | 02-20-2005 04:40 AM |
| Forza Final Car List | Prowler | Members' Lounge | 11 | 01-18-2005 12:20 AM |
| 2002 Ex B16 Sirii Or B18c1 Swap | bboy_kaos0203 | HYBRID -> EG-EK / DC | 1 | 04-09-2003 10:39 PM |
