iv had my engine light on for about a week now and im scared to drive my car at first when i got a diagnostic it was a code p1337 and auto zone said i needed to replace my spark plugs so i did that and it still didnt go off so i went back and it was the same code but then they said that i need a crankshaft positioning sensor.
does anybody know where this is on a 97 teg, can i replace it myself, and if so can you give me guidence |
Running on two cylinders
Ride: 2000 Mitsubishi Lancer RPW E5 Coupe
your code is leet....
Home of the RPW built 2000 Lancer CC Coupe. See what is done to the little Evo5. "If you don't like what I've done with my car, I will gladly refund all the money you put into it." |
Ride: 2004 Silverado / 1997 Integra LS
Did you ever find out where your sensor was? I also have a 97 integra with the same trouble code.
I replaced the whole distributor and it changed nothing. |
#5 | |
Brutal Moderator
Ride: 97 Integra LS Coupe
Anyway, have you tried resetting your ECU? __________________
#6 |
I didnt realize I was in the wrong forum, but thanks for the info. I cleared the codes with the scanner, but I am unsure how to actually reset the ECU.
#7 |
Brutal Moderator
Resetting the ECU is easy. Just unplug your battery or pull the ECU fuse, let the car sit for a few minutes, reconnect everything, and then turn the car on and let it idle for a while, maybe take it for a drive.
If the CEL comes back after you've done that, then you know it's serious. __________________
| crankshaft speed fluctuation sensor | floridachill71 | HYBRID -> EG-EK / DC | 9 | 04-20-2007 08:56 AM |
| Engine crankshaft | Ivan323 | General Tech and Maintenance | 16 | 03-05-2007 11:06 PM |
| H22A4 Crankshaft | 98h22aprelude | Prelude | 1 | 11-03-2006 08:23 PM |
| Help! Is 94 Accord crankshaft pully bolt reverse threaded? | laffinfish | General Tech and Maintenance | 2 | 08-09-2006 08:44 AM |
| CRANKSHAFT PULLEY NUT,,NEED TO LOOSEN : HOW!!!!! | nightshift | General Tech and Maintenance | 14 | 10-31-2005 03:57 AM |
