Go Back   HondaSwap Forums > Hybrid Forums > HYBRID -> EP / DC5
dc5r into 2002 Ep si
Old 08-03-2004, 11:53 AM   #1
kickz is off the scale
hello
i have just completed the swap .. but ran in tpo a couple of problems heres some info
2002 si
put a jdm rsx type r
dc5r wiring harness.
sir ecu
car starts but have tons of codes such as
3, 6, 7,10,22 and 74
if i plug the dc5r ecu it starts but doenst idle it just dies,,
should i use the stock SI harness??
ima completely lost please help thanks
kickz is offline   Reply With Quote
Old 08-03-2004, 12:37 PM   #2
2265787829
2000Si's Avatar
Ride:  Refer to my name, dumbass.
2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute
2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute
what "SiR" ECU are you using...?
You should probably look for an RSX-S ecu.
2000Si is offline   Reply With Quote
Old 08-03-2004, 07:31 PM   #3
sorry ima from canada. and up here its the SI is called SIR.. sorry about that ..
ok i got the dc5r ecu running .. and it drives good ....
thanks
Old 08-03-2004, 10:10 PM   #4
2265787829
2000Si's Avatar
Damn, you mean I was right?
and I knew SiR but there's also a JDM B16 SiR so I was just wondering which one.
