Go Back   HondaSwap Forums > Hybrid Forums > HYBRID -> EP / DC5
k20a3 swap to run dual cam vtec and k20 into eg/dc questions
Old 04-21-2009, 07:34 PM   #1
Rep Power: 16 tofasttoslowforyou has a spectacular aura abouttofasttoslowforyou has a spectacular aura about
Default k20a3 swap to run dual cam vtec and k20 into eg/dc questions
i have a k20a3 motor but i wanna swap the heads out and run the dual cam vtec head off the top line dc5. i have the base model dc5. Lmk what i need to do or if it possible do to the pistons and or crank, deck clearance to the head.
i was planing on rebuilding the motor to stock specs or through rods and pistons in it.
I was planning to swap the k20a3 into a eg or dc but whats the pros and cons of doing so?
is it better to use the ek chassis?
tofasttoslowforyou is offline   Reply With Quote
Old 07-09-2009, 01:46 AM   #2
Greenhorn
Rep Power: 0 K20Tuned is on a distinguished road
If you plan on swapping the head of the A3 to a A2 you should rework the bottom end while you're there. I suggest bumping up the compression a bit and swapping the A3 oil pump for a A2
K20Tuned is offline   Reply With Quote
JDM D15b vtec Swap Questions HatchHead92 HYBRID -> EG-EK / DC 12 03-15-2008 02:23 AM
Acura RSX 2.0L Engine Swap K20A3 i-VTEC Swap RSS-Bot Auctions 0 02-12-2008 04:03 AM
94 EX w/ Ls Vtec swap questions.. TurboCivic HYBRID -> EG-EK / DC 5 07-08-2007 03:29 PM
d15b vtec swap questions regal1975 HYBRID -> ED-EF / DA 1 05-24-2006 12:05 AM
Ls/vtec Swap Questions... LsVtecYellowMonster HYBRID -> EG-EK / DC 1 03-29-2003 04:45 PM
