Go Back   HondaSwap Forums > Hybrid Forums > HYBRID -> EP / DC5
K24 into RSX-S
Old 06-18-2009, 11:48 AM   #1
Greenhorn
Rep Power: 0 KevinDC5 is on a distinguished road
Question K24 into RSX-S
Hello all, Im new here and am looking for some information regarding a k24a2 into my recently deceased rsx-s. Though I havent torn into the rsx yet im almost certain my head is still good. Im wondering, If I found a k24 lower end and swapped it with my current config. what all am I looking at needing to buy. I plan on using the rsx intake man and exhaust man if possible.
1.What ecu work will i need done.(remember just replacing lower end)
2. Will the stock IM and EM work with the k24 block?
3. Will it fit under my stock rsx hood?
4. These throttle body and intake manifold adaptors everyones talking about...are they necessary if only replacing the lower end and not the head?
Anything else is greatly appreciated!
Thanks in advance!!!
KevinDC5 is offline   Reply With Quote
Old 06-19-2009, 12:33 AM   #2
Dark93DX's Avatar
Rep Power: 10 Dark93DX is on a distinguished road
K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum - Powered by vBulletin
Karcepts Engineered Solutions - Home
K20Z3 EG - Installed, waiting for Kpro
LSD w/ 4.764 FD
B18A CRX
Dark93DX is offline   Reply With Quote
Old 07-09-2009, 01:29 AM   #3
Greenhorn
Rep Power: 0 K20Tuned is on a distinguished road
Q.What ecu work will i need done.(remember just replacing lower end)
A. NO ECU work is required, but you have the option of KPRO later down the road.
Q. Will the stock IM and EM work with the k24 block?
A. Yes, once you keep the PRB head both IM and EM will work.
Q. Will it fit under my stock rsx hood?
A. Yes, fits not worries.
Q. These throttle body and intake manifold adaptors everyones talking about...are they necessary if only replacing the lower end and not the head?
A. TB adapter not needed, only used when running RBC IM with RSX TB.
K20Tuned is offline   Reply With Quote
