Go Back   HondaSwap Forums > Hybrid Forums > HYBRID -> EP / DC5
K24 from TSX vs K24 from CRV
Old 03-28-2004, 09:47 PM   #1
Rep Power: 0 KeLeMi821 is off the scale
what's the difference between the K24 from the TSX and the K24 from the CRV? besides the fact that the TSX has 200 hp and the CRV has 160 hp... and which would probably be better to swap into one of our civics? i'm not planning on doing this anytime soon it's just for general knowledge and maybe i'll do it in the future when the price for k-series motors drops... also is there really an after market for these engines?
KeLeMi821 is offline   Reply With Quote
Old 03-29-2004, 02:47 PM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
The TSX engine has higher compression and more likely a better head configuration, so you would want to use the TSX's K24 instead of the CRV's. You can swap a K20A2 head on if you want too.
Give the aftermarket some time- the B block had a good 12 years to build an aftermarket. The K isn't going to be nearly as large after only 3 years.
Old 04-13-2004, 07:40 PM   #3
Rep Power: 13 Soichiro-Honda is off the scale
Send a message via AIM to Soichiro-Honda
There heads are the same, there VTEC is different.
TSX has throttle by wire system you don't want to use its head or Intake manifold.
CR-V and TSX have the Same Crank, with a real performance head (k20A2).
CR-V would be the choice.
Its time for me and the Easy 4 to reach our <u>Unlimited Potential.</u>
Soichiro-Honda is offline   Reply With Quote
Old 04-14-2004, 01:19 PM   #4
Calesta's Avatar
Ride:  2003 S2000
Originally posted by Soichiro-Honda+Apr 13 2004, 06:40 PM--><div class='quotetop'>QUOTE(Soichiro-Hon da @ Apr 13 2004, 06:40 PM)</div><div class='quotemain'> <!--QuoteBegin-Calesta@Mar 29 2004, 02:47 PM
The TSX engine has higher compression and more likely a better head configuration, so you would want to use the TSX's K24 instead of the CRV's.* You can swap a K20A2 head on if you want too.
CR-V would be the choice. [/b][/quote]
The CR-V and the TSX have the same head?
Old 04-14-2004, 05:34 PM   #5
US TSX has EGR ports cast into it, and you can't bolt the RSX manifold to it without some modifications. You'd have to use the long runner TSX manifold.
Good thing about TSX it has true VTEC.
Old 04-15-2004, 02:47 PM   #6
Calesta's Avatar
Ride:  2003 S2000
Ok, that makes sense. It still shouldn't matter if you're choosing to use the entire K20A2 head on top though, right? How close are the TSX / CR-V heads to the RSX-S head?
Old 04-15-2004, 09:24 PM   #7
Originally posted by Calesta@Apr 15 2004, 01:47 PM
1. It still shouldn't matter if you're choosing to use the entire K20A2 head on top though, right?
2. How close are the TSX / CR-V heads to the RSX-S head?
1. Yeah your right.
2.There different in headflow numbers, ports are dimensionally the same, but k24 flows less. What I mentioned up there k20A2 head does not have. TSX head flows more than the the CR-V.
Old 04-16-2004, 02:30 PM   #8
Calesta's Avatar
Ride:  2003 S2000
1. Ok
2. So no EGR ports cast in and no throttle by wire on the K20A2 head right?
I was under the impression that the TSX short block would produce more compression than the CR-V's. I don't know the compression ratio of each off the top of my head, but I assume that the K24 bottom end off the TSX would still be the prime choice over the CR-V.
Are there any major structural differences between the CR-V and the TSX short blocks? I've read an article by Mike Kojima about how sturdy the TSX block is supposed to be, but I've never seen either K24 torn apart in person.
Old 04-16-2004, 06:29 PM   #9
Exclamation
2. Right
3. There blocks are the same only difference is there pistons. Same stroke, and same bore but you know that.
Heres what I uploaded of the CR-V stock internals, but you prob. seen this already. Theres race design all over the motor, and when modded most likey it WILL show more Torque than H.P. or be very close within each other not far apart like older honda engines.
But when using a2 head or (True VTEC), it's best to use the Type-S or R oil pump.
The only thing I would use that comes with the TSX motor is the 6speed which has taller gears better for boost (which has a F.D. gear thats similar in # to the Type R), and the Trans. case is Magnesium something thats not mentioned for the type S or R.
Old 04-16-2004, 07:44 PM   #10
Head comparision.
Old 04-16-2004, 09:13 PM   #11
Calesta's Avatar
Ride:  2003 S2000
Thanks for posting up pictures!
Wow. That's an interesting setup for the A3 head. It almost looks like you could drop in the A2 valvetrain and just have to deal with VTEC oil plumbing issues- the cam support/journals/whatever look like they're all in the right place. I guess one lobe on the exhaust is easier than running two per cylinder with different followers.
I like the piston design. It looks like they did quite a bit more material removal than on the B series pistons. Less mass = more power.
Old 04-19-2004, 04:54 AM   #12
Slo86GT's Avatar
Rep Power: 48 Slo86GT is an unknown quantity at this point
Send a message via AIM to Slo86GT Send a message via MSN to Slo86GT Send a message via Yahoo to Slo86GT
Those exhaust ports are HUUUGE.
- Jody -
2004 Colorado ZQ8 - I5, M5, Regular cab - 209.9whp/210.7wtq
1986 Mustang GT - V8, M5 - 213.0whp/279.2wtq
Slo86GT is offline   Reply With Quote
Old 04-22-2004, 05:33 AM   #13
Gives off a sound unlike any other.
Old 04-26-2004, 06:58 PM   #14
Rep Power: 0 hondp3 is off the scale
hi i work for honda as a tech and i can help u. the k24 block is a great start for a hybrid engine . with a a2 head from a rsx type s (here in the states its all weve got)and a crv block you can create quite a bit of hp and torque . also with the low compession ratio (9:6:1) this swap is just begging for unnatural aspiration . there are a few things to work out like engine to hood clearance, the oil pump , the oil pans need to be switched, changing from 5 to 6 speed , ecu flash from hondata , you need a k20a2 water pump . the best thing for this swap is to have one of both engines so there is no problems with part availability.once all of these things are straitened out you can literally drop this thing in any honda that excepts the k sesies engine . if you have any more technical questions feel free to email me . hondp3@hondaswap.net
hondp3 is offline   Reply With Quote
Old 04-26-2004, 07:09 PM   #15
Blah blah blah....
MikeBergy's Avatar
Rep Power: 49 MikeBergy is on a distinguished road
Send a message via AIM to MikeBergy
lol, like we all have that kind of money, but in a world where honda motors were inexpensive, I'd be all over that.
So the k20a3's don't have real vtec? It totally looks like if you just swapped the a2 camshafts and rocker assemblies, you'd be kosher.
-1991 Integra, lots of goodies in an otherwise stock looking motorp; ITR front brakes.
-Xenocron programmable ecu w/datalogging port, LM-1 wideband, and Moates Ostrich are tuning tools of choice.
RIP 2005 Red Yamaha R6
www.m24x.com - Rocket Motorsports: For more technical engine discussions...
Radar will bounce off of a ride that is shiny and you keep clean.
Please don't PM me with tech questions. Use the forums!
MikeBergy is offline   Reply With Quote
Old 04-26-2004, 11:53 PM   #16
Rep Power: 29 Frankie P. is off the scale
Send a message via Yahoo to Frankie P.
Yes, the A3 doesn't have "true" vtec. I didn't know this when I bought mine, now I wish I bought the Type-S, but I love the shifter in the SI. You can swap the entire vavletrain from a A2 to the A3, it fits perfect but you still end up about 10 hp or so under a stock A2.
Frankie P. is offline   Reply With Quote
Old 04-27-2004, 01:25 PM   #17
Blah blah blah....
MikeBergy's Avatar
10 hp less than the rsx-s? Is that with the type-s ecu and everything? Does the type-s head just flow better, or is there a compression difference b/n the si and thew type-s?
Old 04-27-2004, 02:13 PM   #18
Ride:  '92 Civic CX
Rep Power: 39 D See 2 is an unknown quantity at this point
Send a message via AIM to D See 2
very interesting post... keep the good info coming.
Garage:
1992 CX Hatch > Current Money Pit
Grave:
R.I.P. 1995 Integra GSR
R.I.P. 1990 DX Hatch
R.I.P. 1990 CRX Si
D See 2 is offline   Reply With Quote
Old 04-27-2004, 04:59 PM   #19
I believe there is a .5 compression ratio, the SI might be higher, I am not too sure. I am not too sure if you will lose 10 hp but I heard of a guy who did it, and dyno'd it and ended up with 10 WHP less than a stock type-S, but a lot of different dyno's give a lot of different readings with the new I-vtec, I have seen some dyno's losing only 5-10 WHP from the flywheel, others lose up to 30 so I can't be too sure. The new K-series is a very strange engine, I don't know much on the B-series, and am always learning new stuff on the K. My favorite thing about the K series is how responsive it is to bolt-on's. I hear domestics fan's say well I get 20 WHP with just an intake, and I can say well so can the Type-S. I LOVE IT!!!
Here is a good link for some inconsistency on the dyno's, very frustrating as you can tell.
Superchargers.
Old 04-27-2004, 05:42 PM   #20
Speaking of good bolt-on power here is a great comparison test.
Intake tests.
Old 04-27-2004, 06:53 PM   #21
Rep Power: 15 turboB20hatch is off the scale
Send a message via AIM to turboB20hatch
damn the aem intake really does make 20hp on the rsx typeS
turboB20hatch is offline   Reply With Quote
Old 04-27-2004, 07:23 PM   #22
The DC does a pretty good job too, 19.5 I believe, with slightly more torque, even the ram intakes pull decent numbers, injen made 8WHP, pretty damn impressive if you ask me.
Old 05-11-2004, 01:46 AM   #23
i found some info that you guys might find helpful and really sums things up
it's in sport compact magazine i believe but someone posted the info also on [url=http://www.7thgencivic.com/[/URL]
Posted by Cambo, I'm sure SOMEWHERE this will come in handy.....
K24 Engine Locations and Names:
1. Accord K24A4
2. TSX K24A2
3. Element K24A4
4. CRV K24A1
The Heads:
1. The A4 head: 2 cams lobes on the intake, 1 on the exhaust. EGR Portng
2. The A2 head: 3 cam lobes on intake and exhaust cams. EGR Porting
3. The A1 head: 2 cam lobes on intake, 1 on exhaust.
Compression Ratios:
K24A4: 9.7:1
K24A2: 10.5:1
K24A1: 9.6:1
Horsepower and Torque Ratings:
K24A4: 160 hp and 161 ft. lbs tq
K24A2: 200 hp and 166 ft. lbs tq
K24A1: 160 hp and 162 ft. lbs tq
Differences:
The TSX K24 uses a throttle-by-wire system. The engine is also basically a K24 block mated up with the K-series A2 head (think RSX Type-S K20A2 head). The A2 head is the one you want if you're thinking i-VTEC in the traditional power-maker VTEC system, while the other heads' i-VTEC systems are meant more for emissions and gas mileage.
The K24 block is 19.7mm bigger (height wise) than the K20 block. The K24A2 (TSX) has stronger rods and unique crank. It also sports a 7100 rpm redline, while the other K24 engines have a 6500(?) rpm redline. The K24A2 ECU also isn't compatiable with any other engine for some reason. Thinking about Hondata ECU Reflash? Not for the K24A2 ECU then. Because of the Throttle-by-wire system, Hondata won't be releasing any Reflashes anytime soon (last i heard).
Which Engine Should I Get?
Well, thats tough to say. The K24A1 and K24A4 will be more common than the K24A2. Because they'll be more common, they'll probably be cheaper as well. You can always do a head swap with the K24A4 and K24A1 with a K20A2 Head. You'll have a "poor man's" K24A2, but it'll essentially be the same. The K24A4 and K24A1 are more boost friendly because of their lower compression ratios, but the K24A2 can support light boost. I'd say it'd come down to one of three things or a combination.
1. Do you plan to boost or stay N/A? If boost, go with K24A1 or K24A4.
2. Do you want to be more unique/spend more money? Go with the K24A2.
3. Tranny: 6 speed or 5 speed? 6 speed, then get the K24A2. 5 speed, K24A1 or K24A4.
found here: [url=http://www.7thgencivic.com/forums/showthread.php?s=&threadid=141122&p erpage=15&pagenumber=4[/URL]
Old 05-11-2004, 02:17 AM   #24
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin
in one of the issues of honda tuning(may 2003) the guy that designs honda motors said the tsx's k24 is the best motor they have built. it says the tsx's k24 uses high tensile steel in connecting rod bolts, more aggressive VTEC exhaust cam, increase compression, a second burn system, drive-by-wire, and the transmission case and bell housing is made of magnesium.
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 05-11-2004, 02:52 AM   #25
Rep Power: 28 Bl6CRX is off the scale
Send a message via AIM to Bl6CRX Send a message via Yahoo to Bl6CRX
god damn K series, just when I feel like I really know the ins and outs of B seires...oh well gotta keep up, good thread
Bl6CRX is offline   Reply With Quote
