Seriously, where in the reference is the CEL code chart with a good detailed explanation on how to check CEL codes on the popular honda's?
This seems like it owuld be a given to have on here. Hell, I didn't beleive my friend when he told me that he couldn't find it when he was checking his CEL's the other day. I am tooooooo lazy to mess with it, sorry. I'll just play informant. :P EDIT I was helping check codes on a Skunk2 Chipped P30 in a b16a swapped Del Sol S that looks just like B's car, only faster. __________________
- Jody - 2004 Colorado ZQ8 - I5, M5, Regular cab - 209.9whp/210.7wtq 1986 Mustang GT - V8, M5 - 213.0whp/279.2wtq |
#2 | |
Member of the 20 nut club
http://www.hondaswap.com/forums/index.php?...?act=ST&f=1&t=6
0 Faulty ECU (no signal) 1 Oxygen sensor or circuit. 2 Faulty ECU 3 & 5 Manifold Absolute Pressure (MAP) sensor or circuit. 4 Crank angle sensor or circuit 6 Coolant temperature sensor or circuit 7 Throttle angle sensor or circuit. 8 TDC position/crank angle sensor or circuit. 9 Crank angle sensor or circuit 10 Intake air temperature sensor or circuit. 11 No particular symptom shown or system does not operate - faulty ECU 12 Exhaust gas recirculation (EGR) failure 13 Atmospheric pressure sensor circuit. 14 Electronic air control valve (EACV) 15 No ignition output signal - possible faulty igniter. 16 Fuel injector circuit. 17 Vehicle speed sensor or circuit (VSS) 19 Lock-up control solenoid valve (automatic transmission) 20 Electronic load detector - possible open or grounded circuit in ECU wiring. 21 VTEC spool solenoid valve circuit (Civic & Del-Sol) 22 VTEC oil pressure switch circuit (Civic & Del-Sol) 23 Knock sensor (Prelude) 30 A/T control unit ECM fuel injection signal "A" (Accord & Prelude) 31 A/T control unit ECM fuel injection signal "B" (Accord & Prelude) 41 Heated oxygen sensor - heater circuit. 43 Fuel supply system circuit (except D15Z1 engine) 45 Fuel system out of range - rich or lean 48 Heated oxygen sensor circuit (D15Z1 engine) 50 Mass airflow sensor. 61 Front oxygen sensor response slow. 63 Rear oxygen sensor circuit voltage out of range. 65 Rear oxygen sensor circuit malfunction. 67 Catalyic converter efficency low. 70 Automatic Transaxle problem. 71 through 76 Cylinder misfires 80 Insufficient EGR flow 86 Engine coolant temperature sensor circuit. 92 Evaporative emission purge valve problem *Please only use this as a guide* As some are different. This should only be used as a starting point. __________________
МОΛΏΝ ΛΑΒΈ |
RETIRED
88+ ECU Error Codes
Here's a handy chart for pulling your ECU codes. Pulling the code is a fairly easy process. For 92+ Honda's and 94+ Acura's: Before you can start reading the CEL (check engine light) in your dash, you need to 'jump' your ecu. Here's how. Located the factory two-pin connector of brown and black wires near the ECU on Civics del Sols and Integra's, or behind the center console for Preludes and Accords. Pull that 2-pin out of the main harness. Using a wire or paper clip as a jumper, connect the outputs of the harness together, so that the black wire and the brown wire make a circuit. Once this is jumped together, the dash will start the light show, so its a good idea to jump first, then turn to on. For 88-91 Honda's and 86-93 Acura's: The ECU's on these cars actually have a neat little window right on the computer case. No need to jump here- just turn it to on, and watch it right there through that window. For both steps above, the output will be in a Morse code style of long and short lights. For example, 2 long, pause, 3 short is 23. 1- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor 2- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-89 86-87 n/a 85-87 85-91 n/a n/a Oxygen Sensor "B" defective circuit or unplugged / defective sensor 3- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 MAP Sensor (Manifold Absolute Pressure) defective circuit or unplugged / defective sensor 4- Accord Civic CRV CRX Del Sol Odyssey Prelude 90-98 88-98 97-98 88-91 93-97 95-98 85-98 CKP Sensor (Crankshaft Position Sensor) defective circuit or unplugged / defective sensor 5- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 * 86-98 97-98 85-91 93-97 96-98 85-98 MAP Sensor (Manifold Absolute Pressure) mechanical problem / disconnected piping * exc 94-95 6- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor 7- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 TP Sensor (Throttle Position) defective circuit or unplugged / defective sensor 8- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 TDC Sensor (Top Dead Center) defective circuit or unplugged / defective sensor 9*- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98** 86-98 97-98 85-91 93-97 95-98 85-98 CYP Sensor (Cylinder) defective circuit or unplugged / defective sensor * not a valid code for any throttle body injection Hondas ** not a valid code for V-6 engines 10- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor 12- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 * n/a 85-91 * n/a 95-98 85-98 EGR Lift Sensor (Exhaust Gas Recirculation) defective circuit or unplugged / defective sensor * not a valid code if car is not equipped with an EGR valve (some Civic models are not) 13- Accord Civic CRV CRX Del Sol Odyssey Prelude 85-98 86-98 97-98 85-91 93-97 95-98 85-98 BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor 14- Accord Civic CRV CRX Del Sol Odyssey Prelude 88-98 88-98 97-98 88-91 93-97 95-98 88-98 IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor 15- Accord Civic CRV CRX Del Sol Odyssey Prelude 90-95 88-95 n/a 88-91 93-95 95 88-95 Ignition Output Signal missing or defective ignition output signal 16- Accord Civic CRV CRX Del Sol Odyssey Prelude 90-95 88-95 n/a 88-91 93-95 95 88-95 Fuel Injector System defective circuit or unplugged / defective fuel injector 17- Accord Civic CRV CRX Del Sol Odyssey Prelude 88-98 88-98 97-98 88-91 93-97 95-97 88-98 VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor 19- Accord Civic CRV CRX Del Sol Odyssey Prelude n/a 88-95 n/a 88-91 93-97 n/a n/a Automatic Transmission Lock Up Control Solenoid Valve defective circuit or unplugged / defective solenoid valve 20- Accord Civic CRV CRX Del Sol Odyssey Prelude 90-98 88-98 97-98 88-91 93-97 95-98 92-98 Electrical Load Detector defective circuit or unplugged / defective sensor 21*- Accord Civic CRV CRX Del Sol Odyssey Prelude 94-98 ** 92-95 n/a n/a 93-95 n/a 93-95 VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve * not a valid code if car does not have a VTEC engine ** not with V-6 engine 22*- Accord Civic CRV CRX Del Sol Odyssey Prelude 94-98 92-98 n/a n/a 93-97 98 93-98` VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch * not a valid code if car does not have a VTEC engine 23- Accord Civic CRV CRX Del Sol Odyssey Prelude 98 * 96-98 n/a n/a 94-97 n/a 92-98 KS (Knock Sensor) defective circuit or unplugged / defective sensor * not a valid code if V-6 engine 30- Accord Civic CRV CRX Del Sol Odyssey Prelude 90-98 * n/a n/a n/a n/a 95 92-98 * Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB defective circuit or unplugged / defective sensor * not a valid code for 1996 31- Accord Civic CRV CRX Del Sol Odyssey Prelude 90-95 n/a n/a n/a n/a 95 92-95 Automatic Transmission Signal "B" defective circuit or unplugged / defective sensor 41- Accord Civic CRV CRX Del Sol Odyssey Prelude 90-98 92-98 97-98 n/a 93-97 95-98 90-98 Primary Oxygen Sensor - Heater circuit malfunction 43- Accord Civic CRV CRX Del Sol Odyssey Prelude 90-95 92-95 n/a n/a 93-95 95 90-95 Fuel Supply System defective or malfunctioning fuel supply system 45- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 System Too Lean or Too Rich malfunction in the fuel monitoring systems 48- Accord Civic CRV CRX Del Sol Odyssey Prelude 98 92-98 n/a n/a n/a n/a n/a LAF Sensor (Lean Air Fuel) defective circuit or unplugged / defective sensor 54- Accord Civic CRV CRX Del Sol Odyssey Prelude 96 96-98 97-98 n/a 96-97 n/a n/a CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor 58- Accord Civic CRV CRX Del Sol Odyssey Prelude 98 * n/a n/a n/a n/a n/a n/a TDC Sensor 2 (Top Dead Center) defective circuit or unplugged / defective sensor * with V-6 engine only 61- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor, Heated - Sensor 1 (Primary) high voltage, low voltage, or slow response 63- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor, Heated - Sensor 2 (Secondary) high voltage, low voltage, or slow response 65- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater 67- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system 70- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a n/a 96-98 96-98 Automatic Transmission malfunction with the automatic transmission controls 71- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 1 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire 72- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 2 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire 73- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 3 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire 74- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 Cylinder 4 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire 75- Accord Civic CRV CRX Del Sol Odyssey Prelude 98 * n/a n/a n/a n/a n/a n/a Cylinder 5 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire * valid code for V-6 engine only 76- Accord Civic CRV CRX Del Sol Odyssey Prelude 98 * n/a n/a n/a n/a n/a n/a Cylinder 6 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire * valid code for V-6 engine only 80- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 n/a n/a n/a 96-98 96-98 Exhaust Gas Recirculation insufficient flow detected 86- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-98 96-98 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem 90- Accord Civic CRV CRX Del Sol Odyssey Prelude 97-98 96-98 n/a n/a n/a 98 97-98 Evaporative Emission Control System leak detected in the fuel tank area 91- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 n/a n/a n/a 98 97-98 Fuel Tank Pressure Sensor low input 92- Accord Civic CRV CRX Del Sol Odyssey Prelude 96-98 96-98 97-98 n/a 96-97 96-97 96-98 Evaporative Emission Control System insufficient purge flow Are you done bitching yet? ![]() Last edited by pissedoffsol; 07-12-2006 at 02:07 PM. |
While we're all feeling helpful... anyone have a pinout for the 91 ECU harnesses??
![]() THis is great. Ask and ye shall receive. __________________
#5 |
RETIRED
i can't believe you're a moderator
http://www.hondaswap.com/articles/viewer.php?id=47 you really should read our articles section. lol |
#6 |
I get most of my info from my head, that I post. Articles are great when I need something, but to date, when LOOKING for info, not just browsing, I haven't been able to find chit I'm looking for. :P
| new reference material added | pissedoffsol | Members' Lounge | 17 | 02-12-2004 02:45 PM |
| Dyno chart for my new engine build | Calesta | Engine Building | 36 | 09-18-2003 03:23 PM |
