| | LinkBack | Thread Tools |
| | #1 |
| Senior Member | So I bought a Millermatic 175. It states that it needs 1-phase 230volt power at 19.5 amps. 230V = 220 volts? Does that mean this welder just needs a 220 outlet? And if I wire a 220 outlet or have on wired in my house, will it be single phase? Secondly, I was reading an install guide for a 220v receptacle and it says that depending on what your appliance; Some appliances only require two hot wires and a ground. In this case you can use two-wire cable, just be sure to color code the white wire as a hot wire. Other appliances require two hot wires, a ground wire and a neutral wire. In this case you need to use three-wire cable. How the hell do i know? |
| | #4 |
| Senior Member | Just after I posted this, i went outside to clean my shed, opened up one of my cabinets that's been locked for a long time, and inside found a shit ton of 3 phase wiring & receptacles! ROFL! Score! Not to mention a 60amp breaker... [img]style_emoticons/<#EMO_DIR#>/icon_wink.gif[/img] |
| | #6 |
| HS Troll...And Mod Join Date: Apr 2005 Location: San Antonio, TX Age: 24
iTrader: 0 / 0% Ride: 2001 Honda S2000
Rep Power: 254 | score...just remember NEVER WIRE A BREAKER WITH IT CONNECTED TO POWER.....I still have burn marks on my fingers...Oh well, i was doing God's work. Kids in Brazil now have a church with lights [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] Giggidy. |
| | #7 |
| Senior Member | [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] I already learned that lesson when I watched my girlfrien'ds brother change the heating element in their electric stove with the unit still plugged in. Pushed him back a few inches and ripped his finger wide open. Pretty nasty shit. |
