This is a discussion on Engine/Transmission Change in the NSX, TSX, RL, TL, CL forum
I have a 1999, TL, Auto Tran. with a shifting problem into 2nd gear. My questions are:
1. Can the 2000 TL eng. and/or tran. be directly exchanged with the 1999?
2. Is the tran. removable w/out pulling engine also?
3. How can I tell ...
| | #1 |
| I have a 1999, TL, Auto Tran. with a shifting problem into 2nd gear. My questions are: 1. Can the 2000 TL eng. and/or tran. be directly exchanged with the 1999? 2. Is the tran. removable w/out pulling engine also? 3. How can I tell if the engine is an OBD2b (which I am told are directly exchangeable)? |
| | #2 |
| Pretty sure 1999 was OBD2a and 2000+ is OBD2b. Other than that, I don't know. Good luck! |
Similar Threads | ||||
| 98 honda accord transmission change. | smoothekang | Accord | 3 | 04-03-2011 08:55 AM |
| Transmission Fluid change | Graffiti. | General Tech and Maintenance | 1 | 11-21-2008 04:24 PM |
| transmission oil change | thiebert | General Tech and Maintenance | 9 | 03-27-2007 06:17 PM |
| transmission casing change | word | General Tech and Maintenance | 4 | 07-24-2004 04:38 PM |
| I want to change my engine..... | mare23 | General Tech and Maintenance | 13 | 07-21-2003 03:18 PM |
