Go Back   HondaSwap Forums > Model Specific > NSX, TSX, RL, TL, CL
Free legend, I need help to fix it...
Old 12-08-2007, 12:45 PM   #1
The G37....
get_nick's Avatar
Ride:  Black G37, '07 R6
Rep Power: 266 get_nick has a reputation beyond reputeget_nick has a reputation beyond repute
get_nick has a reputation beyond reputeget_nick has a reputation beyond reputeget_nick has a reputation beyond reputeget_nick has a reputation beyond repute
 FaceBook
Default Free legend, I need help to fix it...
so my friend has a 1991 acura legend his wife wants him to get rid of. it's an automatic, decent body, but just needs it off the road. not sure on miles, we didn't discuss it much. It has a dead battery (not a problem) but there is one problem.
The speedometer spins randomly. it doesn't match the vehicle speed. I guess it just jumps erratically. what would cause something like this and is it an expensive fix?
I changed the page layout. let me know what you think. I need feedback.
www.obamacies.com
get_nick is offline   Reply With Quote
Old 12-08-2007, 03:16 PM   #2
Ride:  06 Chevy Silverado
Rep Power: 88 Jeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud of
Send a message via AIM to Jeef
If you need the speedometer then buy a tomtom 1 for 150 bucks. Its tells you how fast you are going, which so far has been about the same or 1-2mph under what the speedometer was saying. Just keep up with the flow of traffic and you'll be fine. With the dubs on my truck the speedo was off by about 5mph. I never had any problems. For a beater car I wouldn't put a lot of money into it, unless you need to for inspection.
I don't know if it is like Civics but there is a cable that goes into the tranny. I would check to see if the gear is in good shape or if it is seated right. I think that there is a clip that holds it in place, its been so long I don't remember.
Ex 89 crx si,91 & 95 Civic owner.
06 Silverado RCSB 20's, 2/4" Belltech lowering kit, waiting for 2 more cylinders, 1.9 more liters, and 208 more hp engine swap.
Jeef is offline   Reply With Quote
Old 12-08-2007, 10:14 PM   #3
The G37....
get_nick's Avatar
 FaceBook
well, the plan is to fix it and sell it. hopefully get $3k out of it. i want to make sure it's running right.
www.obamacies.com
Old 12-09-2007, 01:59 PM   #4
nootrac22's Avatar
Ride:  daily driver working on 92 prelude 4ws
Rep Power: 228 nootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond repute
Send a message via Yahoo to nootrac22 Send a message via Skype™ to nootrac22
I'd start by checking/ replacing the spedo cable. Would the VSS throw a code? Finally replace cluster.
nootrac22 is offline   Reply With Quote
Old 12-09-2007, 06:34 PM   #5
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
sounds like it could be a signal problem or the cable is loose.
http://pandora.com/
Old 12-09-2007, 07:09 PM   #6
Dismember
Ride:  Whatever i can get behind the wheel of
Rep Power: 263 klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
Either the cable or the gauge itself is probably worn out. Start with the cable.
Go to work, Act normal, Believe the News, Save for your old age, Obey the Law
Repeat after Me: I am Free
klyph is offline   Reply With Quote
Old 12-09-2007, 07:54 PM   #7
The G37....
get_nick's Avatar
 FaceBook
i'll get on it. that would be a fun little flip.
www.obamacies.com
Old 12-11-2007, 09:48 PM   #8
übber ɐɾuıu etarip
Z6CRX's Avatar
Ride:  1995 BMW 318ti, 1985 Honda VF500F(now legal)
Rep Power: 73 Z6CRX has a reputation beyond repute
Z6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond repute
Send a message via AIM to Z6CRX Send a message via Yahoo to Z6CRX myspace  FaceBook
you could always hook up a volt meter to the vss and drive the car to find out if that is the problem. Then make sure theres no cut or protrusions in the wire.
Use a mechanical rather than the digital, for this case, its easier to see spikes, and it can double as your speedo .
Originally Posted by Celerity View Post
No one hates anyone around here more than people hate Celerity. He's an asshole.
Z6CRX is offline   Reply With Quote
Old 12-21-2007, 02:04 PM   #9
DIY god
Swift's Avatar
Ride:  92 acura legend coupe 5spd Type-S
Rep Power: 5 Swift is on a distinguished road
Send a message via AIM to Swift
Its the VSS. you can replace just the electrical part on top vs the whole unit. If the D4 light starts to flash it is defienantly your prob.
good luck.
-Swift
92' acura legend Type-S
http://www.cardomain.com/ride/2895072
*high compression C35 spec-r, custom pullies, custom manifold, custom exhaust, custom chip....etc etc
94' auto coupe
Swift is offline   Reply With Quote
Funny Video Vosty Members' Lounge 7 09-20-2006 12:00 PM
Free Flow Tour 2006 Stops in Dallas!! Seany-izzle South / Southwest 0 06-01-2006 10:09 AM
Free stuff swanny Members' Lounge 14 10-05-2004 11:23 PM
FREE FREE FREE FREE FREE FREE FREE FREE Airjockie Parts: For Sale/Trade/Wanted 33 06-10-2004 06:35 AM
