Go Back   HondaSwap Forums > Model Specific > NSX, TSX, RL, TL, CL
what easily swaps into nsx (besides the obvious)?
Closed Thread
Old 11-09-2007, 09:47 PM   #1
stmotorsports's Avatar
Ride:  2000 Civic Si , 1996 Integra GSR
Rep Power: 21 stmotorsports will become famous soon enough
Default what swaps into nsx (besides the obvious)?
well here's the reason for asking- I *might* have a shot at a recovered theft nsx. Its pretty much stripped- some body parts are missing, a lot of the interior is gone, rims, and of course the driveline.
So this got me thinking instead of trying to track down an nsx swap which will take god knows how long to find a decent setup and which will cost god knows how much and end up being only a stock nsx when done, is there any other cheaper and more readily available C or J motor from a Legend/Accord/Odyssey/whatever else that will more or less interchange?
I figure if a boosted accord or odyssey swap will more or less drop in, it could be easily setup to put down well over stock nsx power, and probably cheaper at that.
anyone happen to have any info on this?
2000 Civic Si: soon to be supercharged B18C1/ITR powered
1996 GSR: daily driver
1996 DX hatch: gf's B20vtec powered dd
1994 Civic EX coupe: sold, wrecked and scrapped
current dream Honda: UKDM Accord CTDi-R
Buffalo, NY- 2ft of snow in October
stmotorsports is offline
Old 11-14-2007, 07:40 PM   #2
Ride:  i have 14 cars i drive my sohc turbo ef
Rep Power: 34 97hatch is a jewel in the rough97hatch is a jewel in the rough97hatch is a jewel in the rough
i do think that a ledgned v6 will fit because i once heard of some one doing a nsx swap in to there ledgned but any thing is posibly with wrenches, welder, and a soldering iron.
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
97hatch is offline
Old 11-21-2007, 01:12 PM   #3
anyone know?
Old 11-24-2007, 05:03 PM   #4
DIY god
Swift's Avatar
Ride:  92 acura legend coupe 5spd Type-S
Rep Power: 5 Swift is on a distinguished road
Send a message via AIM to Swift
first off nobody does swaps into an NSX.
second a supercharged NSX built right can produce over 500hp in a car that is nimble enough stock to beat supercars on a track.
So in my opinion if you can get this car, GET IT, however can you afford it?? If not, a person such as myself would love to get my hands on one to build the motor for it.
Go to ScienceofSpeed.com to find the how to's!
good luck.
-Swift
92' acura legend Type-S
http://www.cardomain.com/ride/2895072
*high compression C35 spec-r, custom pullies, custom manifold, custom exhaust, custom chip....etc etc
94' auto coupe
Swift is offline
Old 11-26-2007, 03:55 PM   #5
ignore
Ride:  90 crx si, e36 m3, cbrF3, 87 civic gl
Rep Power: 12 charleskwinter has a spectacular aura aboutcharleskwinter has a spectacular aura aboutcharleskwinter has a spectacular aura about
myspace
i swear people need to read things more carefully... read this entire thread again please 'swift'.
i was thinking today about the v6's honda has built... to me these motors (i.e. that generation v6) should be interchangeable but the transmission is probably the 'sticky' part. i was given the impression that the nsx has been stroked to 3.2 from 3.0 and tuned, as we all probably know. therefore it seems feasible to do this swap and also gives you the oportunity to do head and bottom end work to your new engine to outperform the stock.
the question i ask for the rest... what is the transmission solution? will all of the v6 transmissions fit? ecu... half shafts... what not. i'm sure someone knows and is intersted.
charleskwinter is offline
Old 11-26-2007, 08:50 PM   #6
blownv6hatchback's Avatar
Rep Power: 5 blownv6hatchback is on a distinguished road
I have a similar question posted at acuralegend.com (does anyone know what engines fit c27 5 speed?) or something like that. Nothing from them yet but I can post more info when I get it.
blownv6hatchback is offline
Old 12-01-2007, 12:19 AM   #7
charleskwinter-
the impression that i've gotten with anyone that i've spoken with about this is that the nsx is completely its own- bellhousing pattern is different, heads won't swap to any other C or J engine regardless of gen, etc etc
I'm basically looking to eliminate the nsx driveline altogether, mainly for availability and financial reasons as mentioned previouly. I'm mostly concerned with differences in mount and axle placement and positioning, physical dimensions (will xxx swap fit in engine bay/clear hatch/correct axle angles/etc)
don't get me wrong- I am definitely not bashing the stock nsx gear. I would love to come across a mint, unmolested, completely intact nsx for a ridiculously low price. As swift posed the question if i have the finances available to make some crazy shit happen like a supercharged nsx, yes i do. However I have no desire whatsoever to tie up upwards of $50 in a car, a summer-only car at that, when my finances could be much better invested elsewhere, which they currently are.
As I mentioned in the original post, the car I have a chance to pick up is being offered at such a retarded price, it would almost be stupid to not jump on it. But if it's going to cost me $30k to put it back together, then I'm going to have to pass. Just trying to find a happy medium somewhere I guess.
blownv6hatchback-
definitely post back if you find anything out!
Old 12-09-2007, 03:32 AM   #8
hondarin's Avatar
Ride:  1992 H22A Accord EX
Rep Power: 27 hondarin is a glorious beacon of lighthondarin is a glorious beacon of lighthondarin is a glorious beacon of lighthondarin is a glorious beacon of lighthondarin is a glorious beacon of light
Send a message via AIM to hondarin myspace
Well, first of all, the NSX has DOHC. Also, I believe it's a 90 degree V6. Based on these two facts alone, it's pretty safe to say that the NSX V6 is larger externally than a J series V6. Assuming that you're able to fab up your own mounts, a J series V6 *should* fit. Now, I haven't personally taken any measurements, so don't quote me on this, but I don't see any reason why a J series V6 wouldn't fit in an NSX engine bay. As far as axles go, I have no clue, but most likely you would have to get some hybrid axles made.
All in all, I would think that you could come out cheaper with an Accord V6 with custom mounts and custom axles, than if you sourced an actual NSX engine.
If you really wanted to go out there with it, maybe even a K24/20 hybrid and a fat turbocharger..... that's just my imagination running wild though.
Originally Posted by phyregod View Post
Front page has the 6 most visited websites. Mine will be porn, ... porn, hondaswap.
...And personal bench testing shows that it does not play well with IE...(Read: Watching the same video refreshed both at the same time, chrome pops up happy, IE flops up a "ZOMGWTF" message.
FAEN!!! says:
cause enter is the new send
Darin says:
okay, but if i'm already using my mouse to paste something, i don't want to move my hand all the way from my mouse to my keyboard when i could've just clicked "send"
hondarin is offline
Old 12-09-2007, 09:02 AM   #9
Rep Power: 25 MXDesa will become famous soon enoughMXDesa will become famous soon enough
Send a message via AIM to MXDesa
I have disassembled and overlooked a lot of NSX powertrains in my honda days and the drivetrain is different from any other honda motor. The transmission is uncommon to hondas as we know them. So to swap another type of v6 into it, would be useless because you would have to completely change the position of the motor for the axles to even remotely fit right. Try and locate a NSX powertrain because there is nothing like a NSX. A stock one you will love it!
2003 EP3 Civic SI - Pretty Much Stock (for now)
1990 Eagle Talon TSI Turbo AWD
2005 Kawasaki ZX-6R - 10.58 ET at 137 MPH
MXDesa is offline
Old 12-09-2007, 07:52 PM   #10
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin
Mugen V8
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
K2e2vin is offline
Old 12-21-2007, 02:08 PM   #11
DIY god
Swift's Avatar
I know more than anyone here about honda V6s probably except for the member above that had taken a few apart.
Then NSX block only shares similiarites to the C27a in the first legend. Thats it.
There is no reason to spend more money on a swap that probably wont go smooth.
I think you have no cash, cant afford even a used block and now your just trying to swap in a motor to sell the car.
Any NSX owner wont touch a car if the VIN or the mileage doesnt add up.
-Swift
94' auto coupe
Swift is offline
Old 12-21-2007, 02:09 PM   #12
DIY god
Swift's Avatar
PS- on second thought, where is the car, i will buy it and do it right.
-Swift
94' auto coupe
Swift is offline
Old 12-21-2007, 03:02 PM   #13
you're the man
MXDesa is offline
Old 12-21-2007, 06:59 PM   #14
wow. thanx for the $0.02. Unfortunately, thats about all it was worth. Not that I have to try and brag or anything, but I probably have more invested than the house you live in is worth. Those who know me can vouch for that. I was just asking a simple question, exploring an idea and/or possibility that seemed intriguing and interesting to me. As I mentioned originally, which I *thought* I made pretty fucking clear, I wanted to see if something with more or similar performance potential could be swapped into the nsx chassis for less than it would cost to get the same or less potential out of a much more expensive (read: stock driveline) swap. Much I'm sure like the first individuals that tried swapping different series engines into the "wrong" chassis. And also much like them I have to hear my share of bullshit from peeps like you because I proposed something that isnt of the usual, boring realm of things.
If all you're going to do is bash other peoples ideas and be a small minded cynical smartass dipshit drama bitch then stay the fuck out of my thread.
Old 01-03-2008, 02:38 PM   #15
DIY god
Swift's Avatar
If you knew anything about me i have gone way outside of the box in terms of swaps etc.
Also if you knew anything about the NSX, its an aluminum body with a subframe in the rear. If you knew how the engine/trans was setup for the RWD you would see you almost have very few if any options in terms of swaps. You were asking for input and opinions on a subject you were to lazy or have no experience in looking into is all. People have swapped LS motors into 350Z etc however the platform in a whole is similiar.
The engine itself is worth over $10k alone and can be built correctly and cheap if you retain the stock rods etc and keep HP around 400whp.
-Swift
94' auto coupe
Swift is offline
Old 01-04-2008, 12:22 AM   #16
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Sorry guys, enough bickering.
Calesta is offline
Closed Thread
WikiHow for Swaps drummingpariah Civic and CRX - EF 0 02-25-2007 04:39 PM
stupid horescope shit... pissedoffsol Members' Lounge 4 03-16-2006 01:24 AM
do you fit the description? pissedoffsol Members' Lounge 25 07-20-2005 09:37 PM
Non-recommended motor swaps pissedoffsol Swap Articles 1 04-08-2004 03:29 AM
