Discuss Swap information, turbo installation, general Honda tech, ecu chipping, and tuning at HondaSwap.com
I've got a guy wanting to run agains my wrx in an S10 with a 350 in it. Whats the potential of a truck with a motor like that? I know you can probably get stupid fast with them...I've never seen the truck and the guy won't tell me anything about it. Ever see a setup with something like that in it?
<span style=\'color:red\'><u>SOLD</u></span> <u>Car:</u> 99DX Hatch <u>Motor:</u> 99 JDM ITR <u>Race Prep:</u>Hasport mounts, Skunk2 tie bars, custom CAI, ACT flywheel and clutch, H brace, Skunk2 camber kit, Custom LCA's. Work RSZ-R(track) Rota Group-N(Street), Fully gutted and stripped. Apexi WS2 catback w/test pipe. Corbeau FX1 Seat. Custom Racing Pedals. <a href=\'http://www.hondaswap.com/forums/index.php?act=module&module=gallery &cmd=user&user=31889&op=view_album& album=120\' target=\'_blank\'>My Old EK Photos</a> <a href=\'http://www.hondaswap.com/forums/index.php?act=module&module=gallery &cmd=user&user=31889&op=view_album& album=158\' target=\'_blank\'>My WRX Photos</a> <u>My Elise Photos</u> (coming soon - backorder is a bitch) |
www.s10forum.com
S10s can RALLY!!!! |
#3 | |
LS1/LS6 You'll probably get owned.
XBL Gamertage: CamelPepper Game: Call of Duty 4. Watch out for the M4 Carbine. Mods: Injen SRI, DC Sports 4-1 Header, A'pexi WSII catback, and (at some point...) S2 shifter, IM, coilovers. __________________ Last edited by 2000Si; Today at 04:07 PM. |
You will have a traction advantage over him, but if he can hook you might get worked. It also depends on the motor like was stated earlier an LS1/LS6 has the ability to work you over.
2004 Toyota Tacoma 3.4L V6 TRD Package 4WD ---------------------- |
#9 |
You will get owned. Especially in your honda. Expect it to put out at least 300 hp and weigh no more than your wrx. More than likely its a 2 wheel drive so it will probablly weigh less.
My roomate has a 91 s-10 blazer that we were going to throw a 350 in but he decided to build and turbo the 4.3 litre. It will be MUCH faster than any 350 could. Super Typhoon anyone? ![]()
Latest project - 1 fucking fast 99 SI
#10 |
Ride: 06 Chevy Silverado
Does anyone know how much it would cost to put a 350 into an s10? Just like all the parts to do the swap not including the engine? I want to rock one.
Ex 89 crx si,91 & 95 Civic owner. 06 Silverado RCSB 20's, 2/4" Belltech lowering kit, waiting for 2 more cylinders, 1.9 more liters, and 208 more hp engine swap. |
#11 |
The 350 is like the B16 of hondas, a million and a half parts and ways to make it faster. Chances are it will be a really really close race. And if your cars into the 13s i would say go for it.
97 Acura integra GS-R AEM cold air intake Apex-i N1 cat back Dc header best 1/4 15.4 --------------------------- |
#12 | |
There's a ton of Chevy motors that are 346-350 CI's.. The 93-96 LT1, LT4, 97-04 (I'm including C5 engines in this one, yes I know the Camaro was 98-02) LS1, 01-04 Z06 LS6, 05+ C6 LS2 and the (probably) soon to come out LS7 C6 Z06 motor. The LT1 will be the cheapest, but makes less power. You can also get aftermarket built 350s that can range anywhere from 350-600 hp on pump gas.
#13 |
Fuck it then...I'm only able to put out a 12.4 in the subaru right now...well close to it anyway....its done lower, but not with me driving and the clutch is starting to slip. He wanted to run me for $500 but I didn't trust the guy trying to get me to race him. I don't like street racing anyway.
#14 | |||
a chev 350 comes in 70 % of older trucks out there just go to a bone yard and pull one build mounts put in the 4 wires and your down Quote:
again, depends on which motor you choose and where you get it from. I don't feel like going to rummage through my CHP magazines right now. There's a ton of Chevy motors that are 346-350 CI's.. The 93-96 LT1, LT4, 97-04 (I'm including C5 engines in this one, yes I know the Camaro was 98-02) LS1, 01-04 Z06 LS6, 05+ C6 LS2 and the (probably) soon to come out LS7 C6 Z06 motor. The LT1 will be the cheapest, but makes less power. You can also get aftermarket built 350s that can range anywhere from 350-600 hp on pump gas. [/quote] you only thinking of newer motor the 350 has been around for 40 years |
#15 | |
Ride: 91 CRX
You can probaly find a( 1960-1968) 350 Long Block for $200. the earlier years are more desireable as they had a higher nickle content and came with 4-bolt mains. a much stronger block to start out with Rebuild it with 10.5:1 Pistons Cam w/ this profile .555intake , .555 exhaust 1.6:1 Roller Rockers New Timing Chain 2.02 (fueley heads) 7/8" Large Tube Headers, with x-over pipe High Volume, High Pressure Oil Pump. Rebuild the 650 Holley Carbs and get a vicktory Jr. 4+4 intake and an MSD 6AL Ignition this can be done for under $2000 if you do alot of the work yourself. about 375HP, 400+ ft-lbs torque Rebuild TH350 tranny with shift kit, hardened sprag and intermediate gears, hardened pump stator, and a master rebuild kit w/ a 3000rpm stall converter ($800) get a set of lakewood traction bars, and a 10bolt posi rear end. and pull low 13's all day --how do I know because I built a very similar motor for an old camaro--
Dennis Please don't PM/Email/IM me for technical support. Make a Post!!! 91 CRX DX, 03 Civic EX "There are 10 kinds of people in the world: those who get binary and those who don't." "Of all my imaginary friends I don't think there was one I didn't end up having to kill" |
#16 | |
15 second IROC Z 350s weren't fast. :P
#18 | |
Ride: 91 CRX
Depends on how the 350 was built. If it was truely built to be used as a truck it will have a low lift longer duration cam profile, which is really nice for producing gobs of torque, it'll redline at like 5000RPM. you'd most likley walk all over it. If it was built for racing, well it's most likely got a high lift mild deration cam with a tunnel ram or some other single plane intake. and will make gobs of HP from the 3000-6000rpm range. and will produce well over 375hp and will most likely give you a hell of a run.
#19 | |
Ride: 91 CRX
true , but he said big block S10, which means it's either got a 400BB, or a 454 in it. and I believe they made a 454SS S10 for a few years stock from the factory
#21 |
Ride: 91 CRX
^ and that's a problem ?
93 octane rated fuel still cheap enough not to have to worry about if your looking for a killer motor like a 454
#23 |
454 in an S10 BWAHAHAHHAHAHAHA from the factory BWAHAHAHHAHAHA
1 4.3 liter largest motor every offered factory for the S/T trucks 2 Big block can only be put in S/T trucks with a minor modification, MOVING THE FIREWALL BACK, aswell as better suspension, reinforcing the chasiss,etc 3 454SS was offered, it was a Half-ton pickup 4 350s IMO can be built much better(more power more reliability) than a 454 5 I do not believe 454 take premium fuel |
