Go Back   HondaSwap Forums > Members' Corner > Other Vehicle Discussions
98 Legacy GT, Thermostat
Old 04-08-2008, 09:07 PM   #1
Yeah
EF9_Hatch's Avatar
Rep Power: 32 EF9_Hatch has much to be proud ofEF9_Hatch has much to be proud ofEF9_Hatch has much to be proud ofEF9_Hatch has much to be proud ofEF9_Hatch has much to be proud ofEF9_Hatch has much to be proud ofEF9_Hatch has much to be proud of
Send a message via AIM to EF9_Hatch myspace
Default 98 Legacy GT, Thermostat
Hey hows it going? My buddy has a 98 Subaru Legacy GT. Today when he was coming home from work it overheated, BUT when he popped his hood, his radiator was really cold, the cap was not even hot after over an hour of a drive. He came home, and told me about it and I immediately said thermostat got stuck closed, and didnt open at all. Well we went to go to get the part for me to change it and his car was running fine. It didnt overheat at all, it stayed right in the middle where it should be. He even got on it a little bit and it just stayed right there. So my guess is that it just got stuck closed, and I plan on changing it either tomorrow or thursday, but I'm wondering if anyone knows where it is located? Ive done it before on different cars but never a Subaru... So does anyone know where it would be located at? Thanks for all your information and help!!!
"It takes a strong person to open themselves to criticism, and a weak person to sit behind a computer screen and criticize."
girl wobble it, and ima gobble it.
XBL Gamertag= W0BBnIT <---- 0 is a Zero
EF9_Hatch is offline   Reply With Quote
Old 04-08-2008, 09:24 PM   #2
t3t4delsol's Avatar
Ride:  97 del sol si turbo / dd is a 95 eclipse gsx
Rep Power: 10 t3t4delsol has a spectacular aura aboutt3t4delsol has a spectacular aura about
most cars have it located inside a housing on the top of the block, find the rad, and follow the top rad hose to the block, the housing should be there
t3t4delsol is offline   Reply With Quote
Old 04-08-2008, 09:26 PM   #3
Yeah
EF9_Hatch's Avatar
Yeah i knew that. like thats how the ones ive done, but i figured it might be different and the kids dad said that its under the water pump and i said F**K when i heard that, but i have never seen that before so it probably is on top...Thanks though.
Old 04-09-2008, 09:01 AM   #4
nootrac22's Avatar
Ride:  daily driver working on 92 prelude 4ws
Rep Power: 103 nootrac22 has a reputation beyond repute
nootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond reputenootrac22 has a reputation beyond repute
Send a message via Yahoo to nootrac22 Send a message via Skype™ to nootrac22
1998–2005
  1. Raise and safely support the vehicle.
  2. Remove the engine undercover.
  3. Drain the engine coolant.
  4. Loosen the hose clamp and disconnect the lower radiator hose from the thermostat cover.
  5. Remove the thermostat cover and gasket, and pull out the thermostat.
    Remove the thermostat cover, and pull out the thermostat—2.5L engine shown
    Exploded view of the thermostat and related components—2.5L Turbo engine shown
To install:
  1. Install the thermostat in the intake manifold.
    NOTE 2.2L, 2.5L engines—The thermostat must be installed with the jiggle pin upward.
    NOTE 2.5L Turbo engines—The thermostat must be install with the jiggle pin facing front.
  2. Install the thermostat cover together with a new gasket.
  3. Install the lower radiator hose to the thermostat cover and tighten the hose clamp.
  4. Install the engine undercover.
  5. Lower the vehicle.
  6. Refill the engine cooling system to the correct level.
  7. Start the engine and check for leaks.
    Ensure the jiggle pin faces upward—2.2L and 2.5L Engines
nootrac22 is offline   Reply With Quote
Old 04-09-2008, 09:06 AM   #5
Yeah
EF9_Hatch's Avatar
Thank you sir! I appreciate it.
Old 04-09-2008, 10:01 AM   #6
nootrac22's Avatar
anytime.
Forum Jump
Mugen Low-Temp Thermostat team1320_k24eg Parts: For Sale/Trade/Wanted 0 05-04-2007 12:59 AM
160 degree thermostat / Hondata gasket 99sidude General Tech and Maintenance 0 03-26-2007 12:29 AM
honda oem thermostat vs. napa oem thermostat m2slsvtec671 General Tech and Maintenance 4 07-26-2004 11:53 AM
WTF? Where's the thermostat? sohcslammer General Tech and Maintenance 4 10-13-2003 10:58 PM
low temp thermostat or OEM? seanjuan General Tech and Maintenance 6 09-11-2003 04:49 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
